Hood/fenders/grill don't line up...
Results 1 to 7 of 7
This is a discussion on Hood/fenders/grill don't line up... within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Since I've had this car, the hood has never quite matched up with the grille. On top of that, it ...
    Feb 2011
    Austin, TX
    Since I've had this car, the hood has never quite matched up with the grille. On top of that, it used to flop up and down at highway speeds. I fixed the flop by simply raising up those little rubber dampers (not sure what they're called), but now the hood doesn't even match the fenders. It sits quite a bit higher than the grille and sticks out farther than it looks like it should.
    Does anyone know if there's something I can do to fix it?
    (Pictures to come, very soon)
    Feb 2011
    Austin, TX
    I know it's dirty... it keeps raining, so there's no point in trying to wash it
    Gold Member lokey's Avatar
    Jan 2011
    Crofton, MD
    If you were to push and hold the hood down, is it flush then?
    Greg
    Build Thread
    ProTuned Stage 3ish '11 WRX Ltd HB (SWP) ~ 354 awhp 404 ft-lb tq on E85
    Friends don't let friends drive Mitsubishis.
    Feb 2011
    Austin, TX
    I'd have to lower those little rubber stops to check. Is there a way to get the hood to latch lower?
    Jan 2011
    Crofton, MD
    That's why I asked. I suspect the hood latch mechanism may be seized up, or is damaged/bent. When you "pop" the hood, does the hood spring open about an inch more than it is in these pics?
    Try spraying the whole mechanism with pb or wd40 first - http://forums.nasioc.com/forums/show....php?t=1906688
    Greg
    Build Thread
    Feb 2011
    Austin, TX
    Quote Originally Posted by lokey View Post
    Try spraying the whole mechanism with pb or wd40 first - 02 WRX hood won't close .. - NASIOC
    I lowered the rubber stops to the bottom, hit it with PB, and open and closed it a bunch of times to make sure. It comes down a bit lower (because the stops aren't holding anything), but has extra play (which will make it vibrate at hwy speeds). It still wouldn't go low enough to meet up with the rest of the grille or head lights even if I push it down. It does pop up when I release the hood, though.
    Jan 2011
    Crofton, MD
    http://www.slidegood.com/02-subaru-w...ood-latch.html
    Does the hood line up in the back? If not, was the car ever wrecked and maybe experienced some frame damage?
    Greg
    Build Thread
