Does not start. any ideas before i start pulling it apart?
Results 1 to 3 of 3
This is a discussion on Does not start. any ideas before i start pulling it apart? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I own a 2002 wrx. The other day I was on my way home when the engine cut out. It ...
    Oct 2011
    I own a 2002 wrx. The other day I was on my way home when the engine cut out. It made no noise whatsoever out of the ordinary before the engine cut off. I pulled off the road and attempted to start the car but it wouldn't start. I had it towed to my house. I checked fuel flow and fuel flow was good. The check engine light had come on shortly before the engine cut off so I checked to see what code it would throw but it showed no codes. I figured then that the timing belt was probably blown, which is a nightmare, but from what I know, the engine should be turning over fast and smooth with a blown timing belt whereas my car is turning over slower than normal. Any ideas what it could be before I go pulling off the rocker cover? It has 131,000 miles. The only aftermarket parts are arm cold air intake and hks blowoff valve.
    Nov 2009
    How old is the battery? What does the car do when you try to start it?
    Oct 2011
    Unhappy
    Battery is about 2 months old. Turns over slower than normal but smoothly. It doesn't stutter at all when it turns over. I believe it could be a ground that's been pulled away but not sure. There was no noise when the engine cut off so it don't feel I blew the timing belt.
