Bouncing Temp Gauge (08' WRX) - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 20 of 20
This is a discussion on Bouncing Temp Gauge (08' WRX) within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Unless you are tracking the car I wouldn't get a cooler thermostat. The injectors and engine burn are calibrated to ...
    Registered User jgardiner's Avatar
    Oct 2010
    Calgary, Canada
    Unless you are tracking the car I wouldn't get a cooler thermostat. The injectors and engine burn are calibrated to run most efficiently at the designed engine temperature. If you change the running temp then the ECU will have to compensate and you won't be running at best efficiency.
    Oct 2011
    Idaho
    Yeah, sounds right. I think what I'm going to do is get a Failsafe brand thermostat that opens at 170 degrees. I've heard good things about Failsafe because if they fail, they will fail in the open position.
    Mar 2012
    Knoxville, TN
    OP, did you ever get your problem figured out?
  6. #19
    Oct 2011
    Idaho
    Quote Originally Posted by bicycle_wreck View Post
    Yes, thank you for asking. From what I've been told is that my K&N intake system makes my car run a little lean I'm about to get it tuned and go from there.
  7. #20
    Mar 2012
    Knoxville, TN
    Thank you for the reply. I took mine into the dealership (under warranty) and they found a bad water pump. They are fixing it sometime this week, once they get the pump in stock. We'll see if that fixes it for me. Car is a completely stock 2012 WRX with 2,100 miles on the odometer.
