Changing oil at 1K and using regular oil to help the rings seat….
Results 1 to 15 of 20
This is a discussion on Changing oil at 1K and using regular oil to help the rings seat…. within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Anyone heard of doing this? A friend of mine said to do this and then change to synthetic at the ...
    Mar 2009
    Anyone heard of doing this? A friend of mine said to do this and then change to synthetic at the next oil change.
    Thank you.
    Apr 2007
    8000' up in Colorado
    Just use synthetic the entire time. Regular oil isn't going to do anything to help the rings seat. Where did your friend hear this?
    Scott
    Jan 2005
    Canada B.C.
    ? I don't know if it's true, but using regular oil for the first oil change is considered better for break in than using synthetic oil, until the second oil change. Then, synthetic would be the way to go... Just the way I understand it.
    '02 WRX 4EAT, 311,000KMs/194,500Miles, Sold. Best car I ever had. '09 STi stage 1, hope this one will be good too...
    Registered User Eric05mx's Avatar
    Oct 2010
    PA
    If we are talking about the 2011's they come with synthetic so just stick with what Subaru recommends.
    2012 WRX ice silver metallic
    Protuned by Agile Auto 315whp/342wtq @ 20.5psi
    Moderator rage-wrx's Avatar
    Aug 2010
    Yonkers/NYC
    This is all too complicated.Just use synthetic oil like the manual says.
    T0ny
    2011 WRX
    2012 FXT
    The Big 2011/2012 Mod Thread
    Mar 2009
    Seems to be quite a popular topic of conversation on the 'Net. Lots of information on the subject.
    Mar 2009
    As far as I know, WRXs are shipped from the factory with synthetic oil….right?
    So if "regular" oil is so much better for break-in, why wouldn't Subaru ship the cars with that oil?
    ClubWRX.net Vendor adam@kronosperformance's Avatar
    Nov 2005
    Princeton, NJ
    I agree...just use synthetic...matter of fact if you want some recommendations let me know
    The Fruit mangostick's Avatar
    Oct 2009
    VB VA .. the ghetto on the sea
    probably old school thought that new (read fresh 0 mileage) engines wont break in or break in slow using synthetic oil.
    OBP 2010 5dr *traded*
    SWP 2013 FRS
    SUCH IS MANGO!
    Quote Originally Posted by wapam View Post
    Excellent point. There are all sorts of theories on break-in and oils, but at the end of the day none of these are supported by anyone that has ever designed or been responsible for the worldwide maintenance of a single Subaru motor, let alone hundreds of thousands of Subaru motors.
    Look at the owner's manual. Find an oil that specifically meets the viscosity and grade requirements, and use it at precisely the intervals dictated. That's it.
    Mar 2009
    Which brings up another question. My manual doesn't specify synthetic oil, it just says that synthetic oil CAN be used. I have heard and read that the wrx needs synthetic oil but am curious why the manual doesn't specify it.
    Moderator Donkey's Avatar
    Da boonies,Va
    Engine Break In Procedure According to Ron at Raw Performance- Great Read - Subaru Impreza WRX STI Forums: IWSTI.com
    "Make sure the engine is full of new non-synthetic oil(see oil suggestions below) and that the oil filter is also full of oil and hand tightened to the engine."
    CobbTuning.com - How To Break-in Your Newly Built Engine v1.03
    Never use synthetic engine oil during this process, use a straight weight, non-synthetic, non-detergent engine oil. You want friction at this point; use an SAE30 oil, non-synthetic, no detergents, etc."
    http://www.cosworthusa.com/store/pc/...ll%20v1.0c.pdf
    "During the break-in process, we recommend using a high quality API SJ or newer mineral 20W-50 engine
    oil. We also recommend using a genuine Subaru oil filter. Do NOT use a synthetic or synthetic blend
    during the break-in process"
    http://www.crawfordperformance.com/contact/warranty.cgi
    " Break-in the motor for 1000miles/1600km using regular (non-synthetic) motor oil"
    2002 FORESTER S
    1998 FORESTER S
    zax
    zax is offline
    Super Modulator zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    Subaru only recently updated the requirement for synthetic oils. It could be that your manual was simply printed before Subaru published the requirement. That being said, synthetic oils have great benefits over mineral oil for any turbocharged car -- specifically the film strength under extreme heat. Though, that's only after the break-in period...
    Zax's Shaggin' Wagon (SOLD)
    Facebook me here
    Aug 2010
    Yonkers/NYC
    I got an addendum to the manual in the mail that says I have to use synthetic oil & change every 7500 miles.
    T0ny
    2011 WRX
    2012 FXT
    Oct 2009
    Crawford Performance - Subaru, Scion, Hyundai Performance
    and this is all absolutely correct for a fresh virgin engine.. But our engines have already had the initial run in haven't they? Every engine I've ever BUILT fresh I followed the non-syth rules for the first 100mi or so, after that changed over to full synthetic. The scoobie I bought new and ran the original oil till the first oil change interval (3750mi) and then switched to synthetic. So far over 60k mi clocked and no consumption/burning issues. I'd go to say it broke in pretty well.
    SWP 2013 FRS
    SUCH IS MANGO!
