EJ257 short block oil consumpsion
Results 1 to 8 of 8
This is a discussion on EJ257 short block oil consumpsion within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; My bro just spent 25K at a tuner shop for a totally new 400ph drive train. He was over for ...
    Oct 2011
    My bro just spent 25K at a tuner shop for a totally new 400ph drive train. He was over for steaks and said his low psi oil light is on and his gauge reads 0 psi @idle. There was no oil in the D@mn thing. It has a A.O.S. on it and 5w-30 syn oil. It was onlt 2500 miles since his last oil change. Is it normal for these to use this much oil? I don't have any experiance with this, any help would be awesome, thanks
    KHP
    KHP is offline
    Registered User KHP's Avatar
    Oct 2010
    Reno, NV
    He drove his car to your house with 0 oil pressure?
    That doesn't sound very good. If he ran the car at 0 PSI oil pressure (at any length of time) I wouldn't surprise me if he somehow had internal engine damage.
    Different engines behave differently. Some engines consume more oil than others. Though it wouldn't surprise me if a highly modified engine consumed a lot more oil than stock or lightly modified. At that power level its completely possible that he's consuming that much oil.
    How often does he check his oil? I check mine once every 2 weeks (my engine is completely stock). Modified engines require more care so owners need to check their oil level more frequently.
    $25k
    2011 WRX Limited Spark Silver (5 Door)
    Apr 2007
    8000' up in Colorado
    What did he have done to the engine for $25k? That's a LOT of money to get only 400 HP.....
    I wouldn't be surprised either if he did some major damage to the engine internals, and especially his turbo. It's unlikely for any engine to burn 5 quarts of oil in only 2500 miles. Is he sure he doesn't have a leak somewhere?
    Normally these engines burn about 1 quart every 2-3k miles, usually a bit less.
    Scott
    KHP
    KHP is offline
    Oct 2010
    Reno, NV
    It's 1qt from full to low on the dipstick. So maybe he's just below low, but then it doesn't make sense since he's not getting oil pressure at all.
    How little oil can you have before the oil pickup starts having issues getting oil?
    Moderator T0rque's Avatar
    Dec 2004
    Medford, Oregon
    If the guy spend 25,000 on a modified motor it best be over 400hp, if it was brand new it should of had oil changed at around 500 as that is usually a recommendation of the builder.
    Lead Wrench @ WTF Tuning, LLC
    Apr 2007
    Quote Originally Posted by T0rque View Post
    If I spent that kind of money and it didn't have over 500 I'd want my money back. That much money should get you a Crawford motor with lots of bells and whistles!
    Scott
    Oct 2011
    Thanks guys. Yea it's a Crawford with a PPG trans and everything else he could upgrade. He says it's 430hp to the ground, well USE TO put 430HP to the ground. I'm just tryin to find out if he screwd up or the shop did. regardless he should have shut it down when the light first came on. Is it common for the rods to hit the cyl walls when a bearing fails, all of my knowlege is in diesels so not a lot of horizontal pistons here. thanks
            MainFrame's Avatar
    Austin, TX
    It's going to have to be at least three quarts low on oil to be sucking air, more like four. Any decently built engine shouldn't consume that much oil, but there are a lot of things that can go wrong in a build to cause it to lose oil. I would consider ~1 quart every 3,000 miles to be acceptable oil consumption.
    My builder, along with most, will tell you to drain the break-in oil at 100 miles, and then change it again at 1,000. Somewhere in between there the shop should have asked him to come in so they could put it on a lift and inspect it for leaks.
    If it's not leaking or smoking, then you need to figure out where all that oil is going. But as others have said, running for any amount of time with zero oil pressure is going to cause permanent damage. If he's lucky only the bearings will need to be replaced.
    I quickly learned that with any new engine build you should check the oil levels very often to make sure something isn't wrong. I'm at 5,500 miles on my most recent engine build and I still check the oil EVERY time I get ready to drive somewhere, and if I'm driving very far I check it at least every time I stop for gas, if not more often.
