Transmission leak (axle to tranny) question
Results 1 to 3 of 3
This is a discussion on Transmission leak (axle to tranny) question within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I see I have some slight tranny fluid seeping out where the axle goes into the tranny (passenger side). Not ...
    Registered User Pavia's Avatar
    Dec 2006
    Philly/DE area
    I see I have some slight tranny fluid seeping out where the axle goes into the tranny (passenger side). Not much, doesn't drip at all on the garage floor, but I assume the seal is bad.
    So how hard is this to fix (replacing the seal) and what's involved cost wise if I had to have a mechanic do it (ie, is this like a simple fix or is it a tear-down type of deal)?
    I'm replacing the clutch in the near future and might just wait til then. Like I said, it's minor and not losing any fluid.
    Thoughts?
    06 GTO M6 Quicksilver, SLP 455 Bobcat, LS7 Clutch w/ SS line (RPM tune:373rwhp/373rwtq)
    07 WRX TR M5 Garnet Red Pearl w/ Straight PPGs and Cusco front LSD (Agile tune:307whp/343wtq)
    Registered User scoobaru03's Avatar
    Dec 2009
    D.C urea, Maryland
    Looked up the labor time for the seals it says for both its 2.6 hours and doing just the one side is 1.4 hours with a skill level of B. Um to my imagination i would expect some level of difficulty. but nothing a diy kind of person with a brain in their head couldnt fix. and a 6 pack of course.
    2003 Impreza WRX Sport Wagon
    "I wouldn't want to belong to a club that would have me as a member." - Groucho Marx
    Is it fast? I don't even know if its street legal. O.o (IROC-Z)
    Aug 2008
    Kennett Square, Pennsylvania
    I have done many axle seals. there is a seal there and there is also an oring once you get the side gear retainer out. When you purchase and install the seals THEY ARE DIRECTIONAL so make sure you install them the correct way. Subaru has a special tool to unscrew the side gear retainer however i find it pretty useless because it usually hits against the engine cradle and its much easier personally when i use a screwdriver and a hammer. When you reinstall the side gear retainers make sure you coat the threads with anti-seize believe me I have been down this road many times...also since those retainers control your front differential adjustment you have to count the turns when you remove them and reinstall them. its a pretty easy job you just have to know what your doing and it just takes a little bit of time.
