What The F*&% is wrong??!
Results 1 to 15 of 23
This is a discussion on What The F*&% is wrong??! within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; When at 5-7k rpm's in 2nd, 3rd, and, 4th gear, my completely stock '04 WRX spudders.. it wont go through ...
    Jul 2011
    Phoenix
    When at 5-7k rpm's in 2nd, 3rd, and, 4th gear, my completely stock '04 WRX spudders.. it wont go through the 5-7k rpm range smothly, it seems like a transmission problem almost like it's slipping but i dont feel anything on the shifter just the engine spudders. It came up with an check engine light once.
    Whats wrong!!??
    Tell us the check engine light code.
    Jul 2011
    Phoenix
    I would, but I don't know how to check it. It went away after I turned the car off then back on.
    Jul 2011
    Phoenix
    I did accidentally fill it with non-premium gas a tank ago so i added two octaine boost bottles to try to get it back up to premium intead of dumping the tank of non-premium gas, and when that tank was 2/3 gone it started to do this. I have used premium every tank before, I just goofed on that one.
    Jan 2005
    Eh, whaaaaa?
    Take it easy until you burn the rest of that tank out, no high RPM's or high loads. Fill it with premium, then reset your ECU. Try again. If problems persist let us know.
    Cody
    Jul 2011
    Phoenix
    Quote Originally Posted by Anub1s View Post
    Ok ill try that, how do I reset my ECU?
            MainFrame's Avatar
    Austin, TX
    Quote Originally Posted by RikRCar21 View Post
    Remove the battery cable and depress the brake for a few seconds. Octane booster doesn't really work BTW.. unless you used like a gallon of toluene, that's what I used to use as injector cleaner/octane booster.
    Apr 2007
    8000' up in Colorado
    Or even easier, just take it to a local auto parts store and ask them to pull the code and clear it for you. They'll do it for free. Post the code up here when you're done.
    Scott
    Registered User GarrettKoonsman's Avatar
    Apr 2009
    CO
    For future reference.....do not do this, ever. A $50 tank of gas is nothing compared to blowing a motor. My guess is that is exactly what caused your problem
    2003 Midnight Black Pearl WRX Sedan
    200.7 AWHP Protuned Stage 2 at 5400ft above sea level
    Bugeye Mafia Member #225
    Mods
    Pics
            MainFrame's Avatar
    Austin, TX
    Quote Originally Posted by GarrettKoonsman View Post
    Theoretically you could fill your tank with 87 and as long as you don't beat on the car and stay out of boost it will be fine until you can run enough out to top it off with 93. I'm guessing there was a WOT event (or several) with the bad gas that was a precursor to the problem.
    Moderator rage-wrx's Avatar
    Aug 2010
    Yonkers/NYC
    I did accidentally fill it with non-premium gas a tank ago .
    Unless you live in Jersey,this should never happen to you.
    T0ny
    2011 WRX
    2012 FXT
    The Big 2011/2012 Mod Thread
    Apr 2009
    CO
    Theoretically yes, I still would never do that though. Anything other than 91 goes into my tank (Colorado doesn't have 93) and its getting drained.
    Mods
    Pics
    Registered User MakeItRoar's Avatar
    Aug 2010
    Chicago, Illinois
    From what I've heard, octane booster only increases the octane somewhere around 1/5 of an "ocatane point" or whatever the unit is per bottle.
    2006 WRX Limited -Pro-tuned VF-39, STI TMIC, STI factory I/C Sprayer, Throttle body Coolant Bypass, STI Exhaust, SPT Short Ram Intake, SPT Upper Front and Rear Strut Bar, Red Samco Radiator Hoses, STI Trunk, SPT Short Shifter, Aftermarket Rotors, Lamco Turbo Gauge, Catless Downpipe, Hella Supertones, RallyArmor Limited Edition Pink UR Flaps, 35% Tint, Grounding Mod, Walbro 255 Fuel Pump, SPT Heat Shield STI Piston Shift Knob!
    Hawk-Eye Alliance #430
    Jul 2011
    Phoenix
    Im having the fuel emptied today, My plan is to fill up with premium, change out the spark plugs (its about time anyways), then reset the ecu... Ive been keeping it under 3k rpms lately, does anyone think I did any real damage? I ll get the check engine code today too and post it.
    Apr 2009
    CO
    hard to know if there was damage done until you have changed those things and see how it runs. Keep it under 3k for the first fifty miles or so to make sure all the bad fuel is gone from the system
    Mods
    Pics
