Code P0341 Car is not runnung Help!
Results 1 to 11 of 11
This is a discussion on Code P0341 Car is not runnung Help! within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I thought the alternator was going because of the whining sound under the hood it would come and go, sometimes ...
    Mar 2010
    I thought the alternator was going because of the whining sound under the hood it would come and go, sometimes revving the engine helped but now its almost a grinding whine, and im getting code po341. Camshaft position sensor Circuit range/ performancs.
    I'm really worried that i broke something hope this is not the case.
    Registered User SoCalWrx07's Avatar
    Sep 2011
    San Diego, CA
    just what i found on google seems like it could be a bad sensor
    A code P0341 may mean that one or more of the following has happened:
    Cam sensor wiring routed too close to spark plug wiring (causing interference)
    Poor wiring connection at cam sensor
    Poor wiring connection at PCM
    Bad cam sensor
    Damaged reluctor wheel
    Hawk-Eye Alliance #619
    Sep 2011
    San Diego, CA
    Registered User scoobaru03's Avatar
    Dec 2009
    D.C urea, Maryland
    P0341
    This is the procedure for diagnosing a P0340 but it is the same for your CEL
    2003 Impreza WRX Sport Wagon
    "I wouldn't want to belong to a club that would have me as a member." - Groucho Marx
    Is it fast? I don't even know if its street legal. O.o (IROC-Z)
    Moderator Donkey's Avatar
    Da boonies,Va
    Clean the sensor face or replace the sensor.
    2002 FORESTER S
    1998 FORESTER S
    Mar 2010
    Ok, I found that the timing belt is loose i dont think it skipped a tooth anywhere though. I cant get the center cover off though, because the crank pully is in the way and I cant find a way to brace the thing so I can turn the bolt. I dont have to use a flywheel tool do I? I tried putting it in gear and locking the brake but it still wants to keep turning.
    Apparently its either the idler pully or the tensioner allowing the slack to throw off the cam sensor.
    Apr 2007
    8000' up in Colorado
    Definitely have that fixed before you drive anywhere. I'd also have a shop check the timing to make sure it didn't in fact skip a tooth.
    Scott
    Mar 2010
    it will definately be fixed before i drive anywhere I just cant find info on how to lock the crankshaft so I can remove the crankshaft pully in order to get ther rest of the timing cover off. I hope i dont have to access the flywheel.
    To remove the pulley solo one has to put the car in a high gear, chock the wheels, and pull the hand brake. Then go at it with a breaker bar if need be. The worry here though is that you said the timing belt is somehow loose, and you definitely don't want to mess with stuff enough to make it jump even if the motor is off. Get a friend to step on the brake and/or get a good air gun.
    There is a tool too but I have never used or I think even seen one in real life.
    Moderator T0rque's Avatar
    Dec 2004
    Medford, Oregon
    +4
    Lead Wrench @ WTF Tuning, LLC
    Dec 2004
    Medford, Oregon
    If you dont have air tools....
