Any aftermarket alum radiators completely bolt-in replacements with no mods needed??
Results 1 to 15 of 22
This is a discussion on Any aftermarket alum radiators completely bolt-in replacements with no mods needed?? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I probably need to replace my stock radiator due to leak at ~80K+ miles. I do not need more cooling, ...
    Registered User mmiller2002's Avatar
    Nov 2007
    Ft. Worth, TX
    I do not need more cooling, I just want a quality, price effective replacement that will bolt-up to everything like the stock unit including fans, mounts, tabs, etc. Prefer not thicker if possible.
    Please suggest products that you've had good experience with, or comment about bad experiences.
    Thanks for any advice.
    Mike
    '02 WRX Wagon
    RCE wagon springs
    Koni inserts
    Com-C Top Mounts
    Kartboy Endlinks
    Sedan rear swaybar
    Others little stuff
    Apr 2004
    Southeastern PA
    A Koyo R2704 fits my 2004 nearly perfectly. It is thicker by nearly double. The only adjustment was trim a bit of the upper radiator hose.
    I'd recommend one.
    2004 OEM radiator is failing. How long do I have to replace?
    Mods & Pics
    Nov 2007
    Ft. Worth, TX
    Thanks! Where'd you get the Koyo?
    '02 WRX Wagon
    RCE wagon springs
    Koni inserts
    Com-C Top Mounts
    Kartboy Endlinks
    Sedan rear swaybar
    Others little stuff
    Apr 2004
    Southeastern PA
    Quote Originally Posted by mmiller2002 View Post
    You have a PM.
    Mods & Pics
    Apr 2007
    8000' up in Colorado
    Why do you say your radiator is due to leak? 80k miles isn't a lot for a radiator if you've replaced the coolant regularly. It could last twice that. Why spend money on something you don't have to?
    Scott
    Nov 2007
    Ft. Worth, TX
    Sorry, I meant due to the fact that its leaking.
    '02 WRX Wagon
    RCE wagon springs
    Koni inserts
    Com-C Top Mounts
    Kartboy Endlinks
    Sedan rear swaybar
    Others little stuff
    I find it surprising your rad lasted 80K miles. I'm on my third radiator.
    Apr 2007
    What are you doing? Filling your radiators with acid?
    Scott
    With love. Love is what makes a Subaru, a Subaru...
    Oct 2005
    Late Devonian
    Plastic end caps - happens all the time. Mine went <80K (current mileage on my '03) and is the only thing that I've replaced because it was necessary in almost ten years.
    My first one went at 6K. My second had been leaking for a while, and I had hoped it was the top hose instead, but it wasn't, plus the top hose fitting collapsed upon inspection and the neighbours are still probably wondering what demon got into me that morning, they must have been able to hear me blocks away. I tend to avoid swearing in English in the top of my lungs so as to not offend (school zone) but the language barrier may in itself have been troubling to them (imagine some guy screaming full blast 0800 or so on a weekday and you can't make out a word, is it better or worse?...). Good times. Went Koyo, OEM style.
    Nov 2007
    Ft. Worth, TX
    ...Went Koyo, OEM style.
    What do you mean by "OEM style"? Plastic?
    '02 WRX Wagon
    RCE wagon springs
    Koni inserts
    Com-C Top Mounts
    Kartboy Endlinks
    Sedan rear swaybar
    Others little stuff
    Nov 2007
    Ft. Worth, TX
    Any opinions on Mishimoto?
    Why would silicone top and bottom hoses be worth the extra $25+ cost over rubber?
    Thanks
    '02 WRX Wagon
    RCE wagon springs
    Koni inserts
    Com-C Top Mounts
    Kartboy Endlinks
    Sedan rear swaybar
    Others little stuff
    Registered User scoobaru03's Avatar
    Dec 2009
    D.C urea, Maryland
    What up man i put a mishimoto radiator in my 03 wrx theres a thread on it with pictures somewhere. You can keep the factory hoses you'll just have to cut them to compensate for the wideness i took off 1/4 in. maybe. I did it little by little till it fit good. You dont need the silicone hoses they just dress up the engine bay a little. Since i replaced it havent had any problems. Now on the down side you wont be able to put headers on your car unless you get the aluminum fan shroud from mishimoto. My opinion on koyo aluminum is the radiators do the same exact thing its just how much you want to spend. i think the koyo was almost an extra 150 dollars. long story short mishimoto is fine and you get a sticker!
    2003 Impreza WRX Sport Wagon
    "I wouldn't want to belong to a club that would have me as a member." - Groucho Marx
    Is it fast? I don't even know if its street legal. O.o (IROC-Z)
    Oct 2005
    Late Devonian
    I have had zero issues with the Mishimoto
