running lean
Results 1 to 5 of 5
This is a discussion on running lean within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I have a 2003 wrx turbo. Ive notice a funny smell when the car is running. I checked the oil ...
    Sep 2011
    running lean
    I have a 2003 wrx turbo. Ive notice a funny smell when the car is running. I checked the oil and sure enough it seems gas is mixing with the oil, also I've noticed my car running sluggish in the low RPM range. What may be the cause of these issues?
    Quote Originally Posted by smokinjoe1978 View Post
    It could be:
    Nothing.
    Vacuum leak.
    Dirty MAF.
    Faulty or clogged injector.
    Ignition fault.
    Fuel pressure regulator fault, including loss of reference vac line.
    Cylinder failure leading to wash down (no combustion or little combustion in one cylinder).
    Without a CEL and from the internet it's not feasible to say more IMO.
    Moderator Donkey's Avatar
    Da boonies,Va
    http://www.clubwrx.net/forums/genera...-question.html
    Gas mixing with the oil would indicate a rich condition,not a lean one.
    2002 FORESTER S
    1998 FORESTER S
    Sep 2011
    so what could cause a motor to run rich and gas mix with oil?
    It could be:
    Nothing.
    Vacuum leak.
    Dirty MAF.
    Ignition fault.
