WRX Front Drive Shafts
Results 1 to 7 of 7
This is a discussion on WRX Front Drive Shafts within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; On my 2003 WRX I've got both inner CV boots leaking as well as one split. In searching the site ...
    Dec 2010
    On my 2003 WRX I've got both inner CV boots leaking as well as one split. In searching the site I see it is about as easy to change the entire shafts than it is to replace the boots. My question is, are both of the shafts the same? Some aftermarket sites show them being the same, but it appears that the genuine Subaru part numbers are different on the left and right, as well as some aftermarket sites list different entries for left and right. I'm confused.
    Answers??
    I have done both boots on both sides. I think they are the same. In any case I would never use aftermarket parts for the axles. Let the dealer worry about what authentic Subaru parts will fit. Aftermarket is not worth the headaches for axle stuff. Do not buy Subaru axle grease though. Costs a fortune.
    Nov 2009
    Just rebuild the axles. It is not hard once the axles are off the car.
    Jun 2011
    Hella, SoCal
    I went through 3 different aftermarket axles before I just rebuilt my OE ones. Was a hassle and a half...
    Dec 2010
    OK You convinced me. Now, the next question is - "What tools do you use besides the (Subaru Special Tools) to tighten the clamps on each end of the boots? The manual shows using a special tool and torque wrench to tighten them properly. What's the trick??
    There are two types of clamps on each axle. One type has "steps" along its path and depending on what step is used, that's how tight the clamp is. The other type uses a "fishing reel" or "winder" type tightening tool. Once you see the clamps you will know immediately what I mean. No special tools are needed; you can use generic tools.
    Nov 2009
    Exactly I used a pair of pliers and a screwdriver to torque down the axle boot clamp. I thought I was going to need some special tools but really didn't. If your car is old and rusty then you will need a tool to push the axle out of the hub. I spent way too much time trying to smack it out. Rust sucks.
