Boost Leak?
Results 1 to 15 of 17
This is a discussion on Boost Leak? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; My car is only running about 8psi and i have an up pipe, exhaust,bov, and intake. Ya the car goes ...
    Sep 2011
    Florida
    Boost Leak?
    My car is only running about 8psi and i have an up pipe, exhaust,bov, and intake. Ya the car goes but i thought stock i should be running around 13psi any help plz??
    Resident Tuner @ WTF Tuning
    Sep 2011
    Florida
    what?
    Registered User GarrettKoonsman's Avatar
    Apr 2009
    CO
    He is suggesting you read that thread. We don't know what kind of car you have, if your tuned, what bov and intake etc. This issue could be everything from the fact that your running a BOV (get rid of that and get a stock replacement), not being tuned, a boost leak, a bad injector, a bad turbo, a bad motor, a bad boost controller, vacuum leak, etc etc. Bottom line, we need more info
    2003 Midnight Black Pearl WRX Sedan
    200.7 AWHP Protuned Stage 2 at 5400ft above sea level
    Bugeye Mafia Member #225
    Mods
    Pics
    Sep 2011
    Florida
    ok thanks ya i just joined today so im learning this whole thing thanks though
    Quote Originally Posted by Z4ck06
    How long has this been a problem?
    You mentioned modifications. Did the 8PSI issue happen after installing one of the modifications?
    Are there any CELs?
    What have you troubleshooted so far? 8PSI is around wastegate pressure; have you tested your BCS to make sure it's operating properly.
    Help us help you...
    Sep 2011
    Florida
    The problem has been there since i got the car. I was told that my BOV could be the problem I have the BOV type s! But i took off my intercooler thinkin i had a boost leak and checked all the lines and everything was fine. I just didnt know how common this was.
    Moderator Donkey's Avatar
    Da boonies,Va
    Read the thread in the link. Then post the answers to the questions here...............
    2002 FORESTER S
    1998 FORESTER S
    Sep 2011
    Florida
    Ok, I have a 2002 wrx with 82000miles on it. I bought it about a month ago and the cel came on. So my friend who is mechanic said it was the exhaust temperature sensor. Here the honeycomb from the cat was all throughout my up pipe. I ended up getting a sti up pipe from a 04 but doesnt have the sensor hole so still my cel light is on. Im not really worried about the cel light at the moment but more of the fact that im only running 8psi instead of around 13 which i think is stock. My aftermarket parts are injen cold air, injen exhaust, bov type s?, and that up pipe.
    zax
    zax is online now
    Super Modulator zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    Quote Originally Posted by Z4ck06 View Post
    First and foremost, if you're getting the EGT CEL, you need to perform the 2.2KOhm 1/2 watt resistor fix: 2.2K Ohm Resistor Mod
    Zax's Shaggin' Wagon (SOLD)
    Facebook me here
    Sep 2011
    Florida
    ok so once i do that what should i do after?
    zax
    zax is online now
    Nov 2008
    Reset the ECU by disconnecting the battery and draining the remaining power, then reassess. If you are still peaking at 8 PSI (roughly mechanical boost) you could have other issues. It's also possible the ECU was pulling boost because of the EGT readings.
    Facebook me here
    Sep 2011
    Florida
    So disconnect the battery for a lil then if that doesnt fix it, it should be another problem? Thanks for the help its just pissing me off, I heard it also could be my BOV??
    Apr 2009
    CO
    It very well could. Get rid of it and put a stock BPV with the recirc hose back on
    Mods
    Pics
    Da boonies,Va
    Could be all kinds of things.
    2002 FORESTER S
    1998 FORESTER S
