Boost gauge only shows 7psi :/
Page 1 of 6 123456 LastLast
Results 1 to 15 of 76
This is a discussion on Boost gauge only shows 7psi :/ within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I have a 2004 wrx and recently got the engine rebuilt due to bad rings then had a horrible misfire ...
    Registered User Clark1989's Avatar
    Aug 2011
    Penn Run, Pennsylvania, United States
    I have a 2004 wrx and recently got the engine rebuilt due to bad rings then had a horrible misfire in cyl 1 then replaced plugs and thr coil for cyl 1 and got a boost gauge installed. My car now lacks accel and boost horribly and still have the occasional misfire or stuttering. Any info on how to fix would help alot! Just bought it a month ago -.-
    Mods: k&n typhoon intake short ram
    Turbo xs rfl recirculating bov and greddy evo 2 catback with a small leak by thr catalytic but have the gasket to replace
    Aug 2011
    Plus today i smelled a raw gas smell
    Supporting Member yamaha_rider619's Avatar
    Jul 2009
    colorado is home, Kansas is the temporary home
    Best thing would be to talk to the person who just rebuilt it for you. Sounds like you could have a boost leak, but if your having a misfire they you have bigger problems.
    Are you tuned for the intake? Catback wouldn't effect boost that extremely.
    Josh
    2003 Subaru Wrx Vf39'd
    Bugeye mafia #300
    Aug 2011
    Not tuned for anything yet just thought that its strange it only runs 7psi shouldnt it be wayyyy higher?
    Jul 2009
    Yes it should be around 12 IIRC. You need to be tuned for the intake. You could be running wastegate pressure. Your need a tune.
    Josh
    Bugeye mafia #300
    Aug 2011
    How can i check for a boost leak? And what would i need to replace thr boost lines or tubo seals?
    Aug 2011
    Could all that make it run like crap bc its not tuned?
    Jul 2009
    Yes if the rebuild isn't all stock parts then it need to be tuned. if you have a stock turbo, ad the seals are going you should have oil burning. Lists all mods and explain what was done in you rebuild.
    Josh
    Bugeye mafia #300
    Aug 2011
    Turbo xs rfl recirculating k&n typhoon shortram and greddy cat back they rebuilt the engine from the block up new valves rings bearings and the whole shebang
    Aug 2011
    Talked to my friend kevin and he suggests the wastegate is sticking open
    Jul 2009
    Yes that's called wastegate pressure. Easiest way to fix it, is to tune the car.
    Josh
    Bugeye mafia #300
    Aug 2011
    Whats the best accesport for my car
    Aug 2011
    Does a short ram work with an accesport? Heard its kinda picky
    Jul 2009
    There is old v1 and there is the newer v2. V2 is definitely better and runs about $350 used if you look around. Make sure you get the one for your car. Ithink is sub-002, but don't quote me on that.
    But you need a protube because of your intake. Accessports are for stock or Cobb intakes.
    Josh
    Bugeye mafia #300
    Aug 2011
    Crap i have a k&n short ram idk if it will work
