Boost gauge only shows 7psi :/ - Page 5
Page 5 of 6 FirstFirst 123456 LastLast
Results 61 to 75 of 76
This is a discussion on Boost gauge only shows 7psi :/ within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Originally Posted by yamaha_rider619 Yes if the rebuild isn't all stock parts then it need to be tuned. if you ...
  1. #61
    Nov 2010
    Richmond Hill, Queens, NY
    Quote Originally Posted by yamaha_rider619 View Post
    Yes if the rebuild isn't all stock parts then it need to be tuned. if you have a stock turbo, ad the seals are going you should have oil burning. Lists all mods and explain what was done in you rebuild.
    im getting the same thing (7lbs of boost) and inconsistent boost , and i definitley smell the oil burning ....what does that mean?
  3. #62
    Supporting Member yamaha_rider619's Avatar
    Jul 2009
    colorado is home, Kansas is the temporary home
    Quote Originally Posted by Clark1989 View Post
    Just fixed my exhaust and now its super quiet! Could i eliminate the midpipe with the resonators and get more sound? Or is it bc it still has a cat?
    The cat does restrict some sound, but a dp would help too. And of course a bigger turbo
    Quote Originally Posted by Kraziee WRX View Post
    List your modifications for us to help you. Oil burning = bad!
    Josh
    2003 Subaru Wrx Vf39'd
    Bugeye mafia #300
  4. #63
    Nov 2010
    Spt intake and spt catback... Thats it....no tune ,...getting a verry heav burning oil smell
  6. #64
    Jul 2009
    Do you have oil dripping and burning off?
    Josh
    Bugeye mafia #300
  7. #65
    Nov 2010
    no oil drips what so ever ... but you can smell the oil being burnt..
  8. #66
    Registered User Clark1989's Avatar
    Aug 2011
    Penn Run, Pennsylvania, United States
    If the seals in the turbo go bad you should have white smoke behind your car yamaha_rider suggested i needed a tune and in the process of getting an acessport for a stage 1 tune then go from there bc if ur car is stuck in economy mode the turbos output is cut in half and my car basically hits a giant wall when i try to boost it goes to 7 then no further no matter how much i mash the throttle i would say either your bearings bad or seals if u smell oil or you may need a rebuild bc ur piston rings control alot also thats what happened to me good luck man these guys know what they are talking about!!! Trust me haha
    2004 WRX Cobb SF
    TurboXs RFL Recirculating
    Invidia V2 DP SRS Catback 285hp 283ft lbs
    Jimmy
    Blobeye Syndicate #3553
  9. #67
    Jul 2009
    We know because we have been there. I have oil burning on the first start up of the day, as my valves are going bad. I also purchased my car used and it had a tune on, so I also was only hitting 7 psi.
    Josh
    Bugeye mafia #300
  10. #68
    Aug 2011
    Just got a stock reflash but found a turbo xs remnant of a piggy back and unhooked it ten reflashed and still at 7 any suggestions?
    2004 WRX Cobb SF
    Jimmy
  11. #69
    Moderator Donkey's Avatar
    Da boonies,Va
    Either: *You don't have the restrictor pill *You have a boost leak *The BCS is malfunctioning *The ECM is detecting severe knock and is defaulting to wastegate boost.
    2002 FORESTER S
    1998 FORESTER S
  12. #70
    Aug 2011
    The bcs was replaced and how do i check for a restrictor pill?
    2004 WRX Cobb SF
    Jimmy
  13. #71
    Aug 2011
    How would i fix the ecm detecting a knock?
    2004 WRX Cobb SF
    Jimmy
  14. #72
    Aug 2011
    Im also getting what i believe to be an egt valve code since removing the turbo xs ecu utec
    2004 WRX Cobb SF
    Jimmy
  15. #73
    Da boonies,Va
    You cannot just "fix the ecu from detecting a knock". First you have to verify there is knock and second you have to determine why there is knock. And there is no EGT valve. It is a thermocoupler. Post the exact code. I honestly would take the car to a professional to diagnose.
    2002 FORESTER S
    1998 FORESTER S
  16. #74
    Aug 2011
    P0546 is the code
    2004 WRX Cobb SF
    Jimmy
  17. #75
    Aug 2011
    Appreciate the feedback donkey the only issue is thr garage that accepts my warrenty doesnt know anything about my car so i turn to clubwrx to help me make him understand. My friend kevin mellot helps allllllot with small repairs bc im a newby to subis
    2004 WRX Cobb SF
    Jimmy
