Boost gauge only shows 7psi :/ - Page 4
Page 4 of 6 FirstFirst 123456 LastLast
Results 46 to 60 of 76
This is a discussion on Boost gauge only shows 7psi :/ within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Absolutely... Any of these vacuum hoses that are placed incorrectly can affect boost. As well, and of them with a ...
  1. #46
    UnBanned Sinister's Avatar
    Nov 2006
    Denver Metro Area
    Absolutely... Any of these vacuum hoses that are placed incorrectly can affect boost. As well, and of them with a hole can affect boost. In addition... an improper tune can affect boost.
    Good luck tomorrow Jimmy!
    Kevin
    Moderator
    Sinister's Blowoff Valve FAQ
    WRX Gas Mileage FAQ
    Firearms Enthusiasts Thread
  3. #47
    Registered User Clark1989's Avatar
    Aug 2011
    Penn Run, Pennsylvania, United States
    Thanks dude!
    2004 WRX Cobb SF
    TurboXs RFL Recirculating
    Invidia V2 DP SRS Catback 285hp 283ft lbs
    Jimmy
    Blobeye Syndicate #3553
  4. #48
    Nov 2006
    Denver Metro Area
    You're welcome Let us know how it goes.
    Kevin
    Moderator
    WRX Gas Mileage FAQ
  6. #49
    Aug 2011
    Would i need to order those hoses and fittings or should they have them
    2004 WRX Cobb SF
    Jimmy
  7. #50
    Nov 2006
    Denver Metro Area
    The dealership should either have them, or be able to get them within 24hrs.
    Kevin
    Moderator
    WRX Gas Mileage FAQ
  8. #51
    Aug 2011
    Well no luck fixed the stuttering but still at 7psi guess i need a tune -.- would a factory tune hurt and where would i get it done? Dont have the cash right now for an acessport unless i can find one cheap
    2004 WRX Cobb SF
    Jimmy
  9. #52
    Supporting Member yamaha_rider619's Avatar
    Jul 2009
    colorado is home, Kansas is the temporary home
    Dealership could reflash your ecu. It would fix your boost but you would still be running bad with the intake.
    Josh
    2003 Subaru Wrx Vf39'd
    Bugeye mafia #300
  10. #53
    Aug 2011
    Would they flash it there and prob expensive?
    2004 WRX Cobb SF
    Jimmy
  11. #54
    Jul 2009
    Yes and I have no idea, call them for pricing. A protune will run you about the same as a used ap.
    Josh
    Bugeye mafia #300
  12. #55
    Aug 2011
    Yea just found that out where can i find a used one?
    2004 WRX Cobb SF
    Jimmy
  13. #56
    Aug 2011
    thinking my car may be stuck in economy mode any ideas?
    2004 WRX Cobb SF
    Jimmy
  14. #57
    Nov 2006
    Denver Metro Area
    if you can find someone with a tactrix cable, they should be able to flash a stock map
    Kevin
    Moderator
    WRX Gas Mileage FAQ
  15. #58
    Aug 2011
    we replaced the selenoid and ran the hoses correctly and checked the wastegate and the wastegate fluctuator and still 7psi its like the car hits a wall when it gets to 7 leading me to believe its def a tune issue or the kid who had it before me had it in economy mode -.-
    2004 WRX Cobb SF
    Jimmy
  16. #59
    Jul 2009
    I'm going to say it needs a tune. Get a tactrix cable, go to a dealership or but a downpipe and get a protune or ap.
    Josh
    Bugeye mafia #300
  17. #60
    Aug 2011
    Just fixed my exhaust and now its super quiet! Could i eliminate the midpipe with the resonators and get more sound? Or is it bc it still has a cat?
    2004 WRX Cobb SF
    Jimmy
