Boost gauge only shows 7psi :/ - Page 3
Page 3 of 6 FirstFirst 123456 LastLast
Results 31 to 45 of 76
This is a discussion on Boost gauge only shows 7psi :/ within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Ask in the thread...
  1. #31
    UnBanned Sinister's Avatar
    Nov 2006
    Denver Metro Area
    Ask in the thread
    Kevin
    Moderator
    Sinister's Blowoff Valve FAQ
    WRX Gas Mileage FAQ
    Firearms Enthusiasts Thread
  3. #32
    Supporting Member yamaha_rider619's Avatar
    Jul 2009
    colorado is home, Kansas is the temporary home
    Great thread jack to help the person I was trying to help.
    Hope it all gets fixed for you, buying modified cars sucks, I personally know. Kevin (Sinister) actually helped me with the same problem you are having now.
    Josh
    2003 Subaru Wrx Vf39'd
    Bugeye mafia #300
  4. #33
    Registered User Clark1989's Avatar
    Aug 2011
    Penn Run, Pennsylvania, United States
    Thanx my buddy mellot is goin to help me change the selenoid then go from there tonite then changing my exhaust gasket got a big leak after the cat
  6. #34
    Jul 2009
    DId you test the solenoid in test mode?
    Josh
    Bugeye mafia #300
  7. #35
    Aug 2011
    Not yet will when he gets here
  8. #36
    Jul 2009
    Do that before you start buying new parts.
    Josh
    Bugeye mafia #300
  9. #37
    Aug 2011
    Will do thank u!!
  10. #38
    Aug 2011
    There was a screw shoved in a piece of hose off my intake!!! Very pissed the garage didnt put it together the right way they should have seen it in my rebuild!! Plus the hose was faulty
  11. #39
    Aug 2011
    need to order stock boost line setup and hook it up right it deffff wasnt hooked up right thank u kevin!!!
  12. #40
    Aug 2011
    new pics are posted in my profile
  13. #41
    Aug 2011
    any ideas where i could get the lines from?
  14. #42
    Aug 2011
    getting vaccum hoses from advacned tomorrow and some t connectors just for backup and hooking this up right the selenoid was hooked up directly to my turbo and not to my intake at all!!!
    2004 WRX Cobb SF
    TurboXs RFL Recirculating
    Invidia V2 DP SRS Catback 285hp 283ft lbs
    Jimmy
    Blobeye Syndicate #3553
  15. #43
    Nov 2006
    Denver Metro Area
    Awesome. Yup.. Sounds like he had the car modified heavily. Make sure you get the lines hooked up EXACTLY how they are in that picture. ALSO... Verify that there is a restrictor pill in the hose! If you don't have one... they are super cheap, and you need to buy one from your dealership. It would also be very prudent of you to go do a couple baseline runs on a dyno with wideband hooked up, and have the tuner look for any knock. You need to make sure that this car's ECU was set back to factory.
    Sorry Josh for ruining your assistance!
    Kevin
    Moderator
    WRX Gas Mileage FAQ
  16. #44
    Nov 2006
    Denver Metro Area
    Quote Originally Posted by Clark1989 View Post
    (MAKE SURE that these are the exact same diameter as the stock hoses... I'd rather see you purchase the hoses and t connectors from a subaru dealership!)
    Kevin
    Moderator
    WRX Gas Mileage FAQ
  17. #45
    Aug 2011
    Could this be why my boost is messed up?
    2004 WRX Cobb SF
    Jimmy
