Bleeding fuel lines to change filter
Results 1 to 3 of 3
This is a discussion on Bleeding fuel lines to change filter within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I was looking up how to change out the fuel filter in my '06 WRX and it seems pretty straight ...
    Registered User spades3443's Avatar
    Jul 2008
    South Carolina
    Question Bleeding fuel lines to change filter
    I was looking up how to change out the fuel filter in my '06 WRX and it seems pretty straight forward, but I was wondering how to bleed the fuel lines properly. I attempted to take out the fuel pump to get to my filter but the main fuel line kept spraying fuel out pretty quickly and wouldn't stop. I had about 1/8th of a tank left, should I drain it completely first or can I still do this with some gas left in the tank?
    Registered User scoobaru03's Avatar
    Dec 2009
    D.C urea, Maryland
    Relieving Fuel Pressure
    1. Disconnect fuel pump relay connector
    2. Start and run engine till it stalls
    3. After stalling crank for 5 more seconds
    4. turn ignition off
    Fuel Filter Removal
    1. Relieve Fuel Pressure
    2. Remove pump assembly
    3. Remove fuel pump
    4. Separate pump from filter
    Install in reverse order
    Make sure you clean off the top of the tank so no debris falls into the tank and no you do not need to drain the fuel just relieve the pressure
    Courtesy of Alldata and me
    2003 Impreza WRX Sport Wagon
    "I wouldn't want to belong to a club that would have me as a member." - Groucho Marx
    Is it fast? I don't even know if its street legal. O.o (IROC-Z)
    Jul 2008
    South Carolina
    Sweet, that sounds pretty easy as well. After all the fuel sprayed out everywhere, the top is already clean haha! Appreciate the info and the help!
