Anyway to disable Hill Assist on a 2011 WRX? - Page 2
Closed Thread
Page 2 of 2 FirstFirst 12
Results 16 to 28 of 28
This is a discussion on Anyway to disable Hill Assist on a 2011 WRX? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Originally Posted by T0rque It isn't the fact that it is keeping me from going forward, it is the fact ...
    Registered User lordgrinz's Avatar
    Aug 2011
    Western, MA
    Quote Originally Posted by T0rque View Post
    It isn't the fact that it is keeping me from going forward, it is the fact that it is making my mind think that I have the clutch holding me where I want to instead it's the actual hill assist.. It's just something that needs to be gotten used to, nothing worth ripping the car apart for.,
    Exactly! and I am 42 also, I don't need a nanny device like Hill-Assist! Grrrr!
    2011 WRX Limited - WR Blue Pearl
    Quick reply to this message Reply
    May 2011
    Quote Originally Posted by lordgrinz View Post
    Why not disable the anti-lock brakes while your at it too then? They're a "nanny" device. You don't need some computer pumping the brakes for you, you can do that yourself.
    No offense, but your "nanny" argument makes no sense to me. There are lots of things the car does automatically that could be done by you with no help from the car. Learning to use the technology to your advantage is what will make you a better, safer driver. Like Torque said, it's nothing worth disabling, just get used to it.
    But hey it's your car...
    But I do agree, a on/off switch for those who want to turn it off would be cool.
    Aug 2011
    Western, MA
    Quote Originally Posted by sho-n-go View Post
    You do know how ABS works, right? Sorry but you can't just pump them that fast....so my nanny argument pertaining to hill-assist which serves no one but first time manual users, is a good one. And yes a simple on/off switch would have been very useful.
  6. #19
    May 2011
    I know how anti-lock brakes work, but 99% of the time you don't need to pump them that fast, you can pump them yourself and be just as safe. If your 42, like me, you've driven many cars without anti-lock brakes and we did just fine. So since they technically aren't needed, like hill assist technically isn't needed anti-lock brakes are a nanny device too.
    Now will anti-lock brakes stop you quicker than manually pumping them... of course. Just like hill assist will hold you in place just as good or better than trying to balance the car on a hill.
    And from your first post, the way it reads you were burning the clutch due to not being used to the hill assist, sounds to me like that's what 1st time manual drivers do. A good manual driver should be able to adjust to new technology very quickly.
    I don't want to get into a big discussion here, I was just curious. You made your point of why you don't like it and I respect that.
  7. #20
    Aug 2011
    Western, MA
    What?! A good manual driver doesn't need Hill Assist, I have never had any issues, and I live in a hilly area....What use is Hill Assist? Explain to me what it does for a good manual driver? If you like nanny devices, then have them put on, the rest of us want a manual like we have had for years. Look on the web, there arethousands of people that don't like or need it, and why give STI owners the ability to disable it, and not WRX owners? Sounds like you need it so bad that you would rather it be on the car, is it because you can't keep from rolling back? I don't know about you, but I don't ever roll backwards, which makes this device worthless.
    And you can dream up all you want that you can out brake ABS, but you're only fooling yourself, its not even a good comparison. Try again.
  8. #21
    Registered User twister8008's Avatar
    Aug 2011
    ND
    Simmer down guys... Agree to disagree on this one.... You might have a stroke. :-)
    Yellow lights mean go faster!!!
  9. #22
    Aug 2011
    Western, MA
    Quote Originally Posted by twister8008 View Post
    Agreed, but I still haven't heard back from the service guy, need to call him tomorrow and see if he got a word back from Subaru on how to shut it off.
  10. #23
    May 2011
    Fine, you want to do this, lets go then moron. First if your 42 then I feel sorry for you because you act and talk like your 13.
    1) Your the guy smoking the clutch. Only someone that doesn't know what they're doing burns the clutch, in any situation. I don't care if hill assist is on or not. A good driver doesn't smoke the clutch and certainly not because of a device that stops the car from rolling backwards. If hill assist throws you off that much that your smoking the clutch then you're clearly an amateur.
    2) Like I said, if you would listen for once, I said hill assist isn't technically needed, but it does serve a purpose. If you can have the car hold you for a few seconds rather than have the need to balance the car putting unneeded wear on the clutch, why not use it. Yes a good manual driver doesn't technically need it, but if it's there and there is no way to turn it off, why not lean to use it to your advantage. Like I said anti-lock brakes aren't needed by a good driver, so why do we all still use them.
    3) The rest of everyone wants hill assist turned off... really, and you have stats to prove that? Thousands say they want it turned off, huh. You sound like a fool right now. You may be able to find people on the internet who want it off, but guaranteed they are thousands, 10's of thousands, maybe hundreds of thousands that like it or don't mind it and have no desire to disable it. Out of all the wrx owners, or owners of any car that have this feature, people who want it disabled I guarantee are in the minority. Just in this thread there are more who don't mind it than want it disabled.
    4) I already said, it would be nice if there was a switch to just turn it off, but there isn't so quite whining like a little baby and deal with it. If you can't adapt, then buy an auto, it's more your speed.
    5) Again, open your ears, I never said I need hill assist or want it so bad. I said it's technically not needed, I don't WANT it, but guess what, it's there with no easy way to turn it off, so learn to drive the car with what's it got and quit whining. It doesn't bother me at all. I don't smoke the clutch because it's there like some who apparently don't know how to drive a manual. I can balance the car on a hill for hours without rolling back if I wanted, can you? But why beat on your clutch when you don't have to. The device is not worthless, it serves a purpose that obviously you can't grasp. Proof is you smoking your clutch. I NEVER smoke the clutch.
    6) Again, listen. I never said I can out brake ABS, in fact I said, ABS will stop you quicker, but technically it's not needed. A good driver can brake in adverse conditions and be just fine. ABS just assists you in stopping, just like hill assist assist you. Since you're small mind can't grasp the concept, let me repeat, ABS assists in braking, but it's not really needed, so the comparison is valid. Are you not capable of stopping without ABS? Of course you are capable, but ABS helps you stop. Hill assist helps as well. At the least it helps cut down un-needed wear on your clutch, at best it helps some from a possible momentary roll back. If you don't roll back EVER, then good for you, but seems to me anyone with any skill wouldn't smoke the clutch because of hill assist.
    7) I was simply curious as to why someone would have a problem with this feature. Now I understand. When your clearly intelligence challenged I can see how such a simple device would throw you off so much.
    Good luck in the future and do us all a favor and disable your air bag as well so we can get people like you out of the gene pool. You can write back all you want, I will not respond any more. I have no time to deal with children like you. I was simply curious but you clearly want to argue like a child. Grow up and get some lessons so you don't keep smoking your clutch. Done!
  11. #24
    Moderator rage-wrx's Avatar
    Aug 2010
    Yonkers/NYC
    T0ny
    2011 WRX
    2012 FXT
    The Big 2011/2012 Mod Thread
  12. #25
    UnBanned Sinister's Avatar
    Nov 2006
    Denver Metro Area
    Okay... have we gotten it out of our systems guys?
    One word: "Done."
    Kevin
    Moderator
    Sinister's Blowoff Valve FAQ
    WRX Gas Mileage FAQ
    Firearms Enthusiasts Thread
  13. #26
    Administrator ...De Rerum Natura TheJ's Avatar
    Bro do you even live in the Dirty South
    Fine, you want to do this, lets go...
    I realize frustration happens but personal insults are not allowed.
    One word: "Done."
    +1
    -The J 𒂼𒄄
    "Driving most supercars is like trying to manhandle a cow up a back staircase. . . This is like smearing honey into Keira Knightly" -JC
  14. #27
    Q RayfieldsWRX's Avatar
    Oct 2002
    The Old Folks Home
    Wow, nothing worse than arrogant old guys.
    --Ray
    "Bro ima get Bimota BB3 because expert. My parents have 911 turbo but awd won't let me launch, ima get 962 twin turbo Group C bro." -- SD_GR
    2013 Subaru BRZ Limited
    2002 Subaru WRX Bugeyebrid Wagon -- SOLD
    2002 Subaru WRX Sedan -- SOLD
  15. #28
    Never trust anyone over 40
    -The J 𒂼𒄄
Closed Thread
