Check Engine light Code PO128
Results 1 to 4 of 4
This is a discussion on Check Engine light Code PO128 within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I recently bought and installed a new Grimmspeed low temp thermostat and a CRXRacing radiator after my stock radiator cracked ...
    Registered User SubaruDewed's Avatar
    Jun 2011
    Red face Check Engine light Code PO128
    I recently bought and installed a new Grimmspeed low temp thermostat and a CRXRacing radiator after my stock radiator cracked Now i keep getting the above code, PO128. Which from what i hear says its a cooling system or thermostat problem. Is there anyway that the new lower temp thermostat is making my engine throw this code? any suggestions would help.
    No luck with the PDF attached?
    New Lower Temp Thermostat Mod.
    OK, I'd contact Grimmspeed and ask their opinion at this point.
    Jun 2011
    The PDF helped. I looked over all the points it said and all was clear. I have a code reader and can clear the code from the engine. When i do this it stays off for weeks if not months at a time...but eventually the code still comes back up.
    Wow. I admit I am baffled. Sorry but I am out of ideas.
