Gates Timing belt and idle question
Results 1 to 4 of 4
This is a discussion on Gates Timing belt and idle question within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I'm needing to change the T-belt but noticed a few part numbers for the kit (water pump, belt, etc) and ...
    Mar 2009
    New Jersey
    I'm needing to change the T-belt but noticed a few part numbers for the kit (water pump, belt, etc) and wanted to know which one's you guys go with. 2006 wrx. Is it worth it for the more expensive blue belt?
    Second, I noticed that when i get off the gas, my idles stays elevated, 1500 rpm, for about 5 to 10 seconds, then goes back to normal. Is this a problem or normal operation? I hand't noticed it before.
    ClubWRX.net Vendor adam@kronosperformance's Avatar
    Nov 2005
    Princeton, NJ
    You would want to buy this particular kit: Gates 04-08 Subaru 2.0L & 2.5L Stock Replacement Timing Belt Kit [TCK328] - $339.58 : Kronos Performance, Leading since 6th Century BC
    As far as the blue belt, I would imagine that its necessary if you're running a high performance, high stress motor. If you're like most street cars, then its not needed.
    Try cleaning your MAF sensor...you don't have an IACV or Throttle Body cables so that kind of rules it out.
    Instead of the blue belt get the regular kit with hhe black belt, the pump, and the rollers but also spent the money to get:
    1. An authentic Subaru water pump gasket and authentic Subaru thermostat gasket.
    2. An authentic Subaru thermostat.
    3. Emory paper, fine. The Gates stuff may have slight burs on the surfaces that contact the belt and if so you will want to smooth them out.
    Sorry forgot to mention that I would get two gallons of the new blue premixed Subaru coolant and one small vial of conditioner.
