p0244 code! help
Results 1 to 15 of 17
This is a discussion on p0244 code! help within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; hey all. i have a 2007 subaru wrx. i have a invidia full turbo back exhaust and the cobb ap. ...
    Jul 2011
    p0244 code! help
    hey all. i have a 2007 subaru wrx. i have a invidia full turbo back exhaust and the cobb ap. after installed car was running fine for the first day, boosting at the target 16 psi with the stage 2 tune. after a day or 2 of driving i started boosting at 21 psi and threw the code p0244. i read that buy using the fuel economy mode i should be boosting at roughly 5 to 7 psi and im boosting at 16 or 17 psi under that tune. i read that by replacing the hose from the turbo to the t fitting and buying a bored out resignator pill should help fix the problem. was just wondering if after i do this and im still overboosting this much is there is any thing else i can do to fix the problem?
    Registered User CSwrx22's Avatar
    Mar 2010
    Central NJ
    I was having somewhat the dame problem. What kind of tune do you have? What worked for me was to lower the WGDC also when I did put the other restrictor in a iwas not boosting enough good luck.
    Jul 2011
    i am using cobbs stage 2 tune 93 octane gas and how do you lower the WGDC and what exactly is that?
    Registered User Lolcanoe's Avatar
    Jul 2011
    Hampton, VA
    COBB Tuning . Subaru WRX AccessPORT . Map Listing
    Wastegate duty cycle. You can change maps to make sure you're not exceeding boost, or under boosting. Make sure you're doing an actual reflash and not a real-time flash. I've heard that can cause problems
    -Stink-Eye Mob #5085 -
    Jul 2011
    Ok how do I adjust my wastegate duty cycle
    Jul 2011
    Hampton, VA
    Reflash your ECU with the appropriate map from the link I posted.
    Jul 2011
    I don't see any link and what map do I want to use
    Jul 2011
    Hampton, VA
    pick your car year, and read what best suits your situation. make sure you read the map notes.
    Jul 2011
    i read the map notes and the only tune that would work is the one i already have on my car. i have the 93 stage 2 on it because i have a stock intake. are there more maps somewhere else other than the few listed after clicking on my year car
    Jul 2011
    Hampton, VA
    the page where you get the maps has the explanation of wastegate duty cycles
    there is normal, HWG, and LWG.
    normal = car reaching target boost
    HWG = car not reaching target boost
    LWG = car exceeding target boost
    Jul 2011
    i notcied on the stage 2 map it says use with a turboback exhaust with a high flow cat but my downpipe is cattless. do they make a map to suit the fact my downpipe is cattless?
    Jul 2011
    Hampton, VA
    as far as i know, all the cobb maps are for catted DP's.
    Jul 2011
    seriously i thought you could run the accessport with a cattless exhaust system. if not then this really sucks
    Jul 2011
    Hampton, VA
    it doesn't say you can't. try a different wastegate duty map. if that doesn't help, post over at cobbforums.com. they are really good about helping people out.
    Jul 2011
    ok and one more question sorry about all this but im having trouble finding the wastegate maps. i click my year car and i see the base maps but no lwg or hwg map
