got a new clutch installed but now its got rough idle, did the mechanic screw up?
Results 1 to 3 of 3
This is a discussion on got a new clutch installed but now its got rough idle, did the mechanic screw up? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Hi, I've got a STI wrx 2000 ra, got a new clutch put into it from a mechanic i dont ...
    Jul 2010
    Hi, I've got a STI wrx 2000 ra, got a new clutch put into it from a mechanic i dont know much about.
    The clutch is really buzzy, but otherwise it seems fine.
    But there is a new problem which is that the car is now idling very rough - the rpms go from 600 to 750 back and forth, lots of shaking, hot and cold - rough idle in both, and this has happened straight after the mechanic installed the new clutch.
    So I called this guy up, and asked him to fix this ROUGH IDLE issue, since it wasn't there before but he says that he only opened up the transmission box and intercooler and he hasn't stuffed it up, but I fail to see how this could have happened other wise.
    So I'm doing some research on this rough Idle issue, if you guys know much about it then please suggest what could be causing this, and if this guy has messed it up or is it coincidental - that is hard to believe; and what action should I take next - how should I talk to this guy, what are my consumer rights?
    Thanks.
    The Fruit mangostick's Avatar
    Oct 2009
    VB VA .. the ghetto on the sea
    sounds like a vacuum leak .. if he removed the intercooler and replaced it.. might want to check to make sure all the hoses/clamps and vac lines are connected. Also check all the grounding wires and make sure they're also firmly attached. He might not have intentionally stuffed it.. but if he forgot a intake clamp (causing a minor leak) or left off a ground wire (causing sensors to read out of range) .. those two aspects could very well cause the issue. I'd def look at vac lines and intake couplers/gaskets first What you have sounds very much like a vac leak.
    OBP 2010 5dr *traded*
    SWP 2013 FRS
    SUCH IS MANGO!
    Moderator Donkey's Avatar
    Da boonies,Va
    /\ Yup either the intercooler pipes are not tightened correctly or maybe he forgot to hook up a couple grounds.
    2002 FORESTER S
    1998 FORESTER S
