need A/C help
Results 1 to 8 of 8
This is a discussion on need A/C help within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; so my A/C works fine but its not really cold so i decide to add more freon, and now when ...
    Aug 2011
    Unhappy need A/C help
    so my A/C works fine but its not really cold so i decide to add more freon, and now when i try to turn it on, my ac the compressor turns on and starts to squeak then shuts off then back on like if its seizing up did i add to much freon or what
    I NEED HELP PLEASE ITS HOT
    Supporting Member yamaha_rider619's Avatar
    Jul 2009
    colorado is home, Kansas is the temporary home
    You could have a bad seal in one of the lines, or your compressor could be going out.
    Best bet would be to buy a gauge and check the pressure.
    Josh
    2003 Subaru Wrx Vf39'd
    Bugeye mafia #300
    Moderator rage-wrx's Avatar
    Aug 2010
    Yonkers/NYC
    Do you have a manifold gauge?How did you know how much R134a to add?
    If you have to add refrigerant,means that you have a leak.
    T0ny
    2011 WRX
    2012 FXT
    The Big 2011/2012 Mod Thread
    Aug 2011
    help!
    i just used one of those gauges from autozone, and my ac wasnt really cold so i put some freon to see if that would help but before that it never did that...... and if i did put to much how can i take some of it out.
    Jul 2010
    Cincinnati
    Take it to a garage, they have a recovery machine and will make sure you have the proper amount of r134. After you know you have the correct amount, you are going to have to get a set of manifold gauges in order to diagnose the problem. If I were you, I'd let a professional handle it.
    Stink eye mob #727
    2011 WRX DGM Hatch, Protuned Stage 1
    Aug 2011
    yeah i will have to do that hopefully i didnt mess it up
    Jul 2010
    Cincinnati
    Quote Originally Posted by scoobywagon1002 View Post
    I'm sure it's fine you just need to get to the root of the problem, it takes a little problem solving
    Stink eye mob #727
    Aug 2011
    well idk what the problem was but ive been using my ac and it hasnt been giving me any problems, hopefully it stays like that, thanks for everyones help
