need help acceleration sucks
Results 1 to 7 of 7
This is a discussion on need help acceleration sucks within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; just got a 2004 wrx wagon and the car drives great, but when i go to WOT i feel like ...
    Aug 2011
    just got a 2004 wrx wagon and the car drives great, but when i go to WOT i feel like the acceleration isnt what it should be, my brother has a 2003 and his acceleration on WOT is much better could i have a vac. leak or is that normal.
    2004 wrx wagon all stock with 99,400 miles 5spd tranny.
    any help would be appreciated
    ClubWRX.net Vendor adam@kronosperformance's Avatar
    Nov 2005
    Princeton, NJ
    What pressure is it building up to? What maintenance have you done to the car?
    Jul 2004
    Seattle, WA
    Does the car have a boost gauge?
    Aug 2011
    i have seafoamed it and that about it and no, no boost gauge need to get one
    Aug 2011
    finally got my boost gauge, car shows at WOT 11 psi but the car still feels like its struggling accelerate
    zax
    zax is offline
    Super Modulator zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    Quote Originally Posted by scoobywagon1002 View Post
    11 psi is low. Stock, you should see ~ 14 psi max boost. This could be a number of things... I'd do some datalogging if possible and definitely check your wastegate actuator arm -- it may require adjustment. There could also be a leak in the vacuum lines leading do your boost control system. Does your car seem to hold 11 psi across approx. 3000-6000 RPM or does the boost waver?
    Zax's Shaggin' Wagon (SOLD)
    Facebook me here
    Aug 2011
    the car hold 11 psi pretty well, i checked some of the lines but found nothing, but the car idles fine and shows 20inmg on the vacuum side of the gauge, is there a good way to check for leaks i read you can make a leak detector buy capping the intake side and applying air to see if you hear leaks
