Results 1 to 6 of 6
This is a discussion on 2002 WRX Oil leak, drivers side. within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; As the title states, I have a 2002 WRX with a drivers side oil leak. It is a mild leak ...
    Jul 2011
    CT/OH
    As the title states, I have a 2002 WRX with a drivers side oil leak. It is a mild leak until after running the car and shutting it off. I do not own the vehicle, I am picking it up Tuesday as we will be purchasing it.
    Valid info: Head gaskets were done at 95k, vehicle is at 105k and it is not leaking there.
    Where I plan on checking: Valve cover, cam seal.
    Any other input/info is greatly appreciated.
    Jul 2011
    CT/OH
    Bump.
    Going to get this car today, the guy is meeting me at my house and taking my father and I to his parents house to use their lift. While it is up in the air, what would you guys look at?
    Moderator Donkey's Avatar
    Da boonies
    2002 FORESTER S
    1998 FORESTER S
    Jul 2004
    Seattle, WA
    Don't take delivery of the car until that problem is fixed.
    My first thought was a came seal too. In order to fix that the timing belt has to come off, and that's a good size project (or some coin). Have them fix it before buying it. Also have the rest of the car inspected buy a certified mechanic.
    Nov 2009
    Doesn't sound too good to me.
    Jul 2011
    CT/OH
    Brought it home today, took off the timing cover on the passenger side, cleaned it out with brake cleaner, jacked it up, and ran it. It was leaking out of the valve cover gasket. I'll be replacing that this week. If it isn't the calve cover, then it's the camshaft bracket that holds the cam in place closest to the gear, which should be an easy fix to just take it off, clean the RTV off the bracket and mating surface, then re-RTV it.
    But thank you guys anyways, glad to know there are helpful people on this forum, and I hope to be like that on here myself.
