Weird overheating issue 2.0 wrx
Results 1 to 3 of 3
This is a discussion on Weird overheating issue 2.0 wrx within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Engine will heat up within 5-10 min of driving. I turned the heat on to try to cool it off ...
    Jul 2011
    Unhappy Weird overheating issue 2.0 wrx
    Engine will heat up within 5-10 min of driving. I turned the heat on to try to cool it off but it's only warm at idle to 1000 rpms, anything higher than idle pretty much cools off to like 75 degrees and doesn't blow hot until I get to the next stop light.might have a little leak up by the radiator but that shouldn't cause it to overheat.
    The long block was rebuilt 3000 miles ago by a reputable shop.....
    Help please
    ClubWRX.net Vendor adam@kronosperformance's Avatar
    Nov 2005
    Princeton, NJ
    Well if you have a leak from the radiator...then you need to have it replaced.
    Registered User scoobaru03's Avatar
    Dec 2009
    D.C urea, Maryland
    they probably dinged the radiator on accident putting it in or taking it out and if it is leaking coolant it will overheat
    2003 Impreza WRX Sport Wagon
    "I wouldn't want to belong to a club that would have me as a member." - Groucho Marx
    Is it fast? I don't even know if its street legal. O.o (IROC-Z)
