Turbo Timer not working
Results 1 to 10 of 10
This is a discussion on Turbo Timer not working within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Hey everyone, So I'm having issues with my turbo timer as well as other electric aspects of my car. My ...
    Dec 2010
    Hey everyone,
    So I'm having issues with my turbo timer as well as other electric aspects of my car. My turbo timer no longer keeps the car running even when it's turned on. Also, when I turn my car all the way off, the clock and radio are still on. Furthermore, the green ring around the ignition stays on. And then my alarm decides to go off at random times even when nothing is around it. It's such a pain and I have no idea what may be causing this. Any ideas? Thanks for your help!
            MainFrame's Avatar
    Austin, TX
    First thing I would do is remove the turbo timer. There's no need for it, and being that it is the odd component in your electrical system, chances are it is what's causing the problem.
    Dec 2010
    It was working fine before though o_o. I had work done on my car however.
            MainFrame's Avatar
    Austin, TX
    What did you have done? (I would still remove the TT)
    Dec 2010
    I had a spark plug socket replaced and 4 new spark plugs put in.
            MainFrame's Avatar
    Austin, TX
    New coilpack? Then I would check/clean the grounds around the area that was worked on.. it actually wouldn't hurt to clean all the grounds in the engine bay. Do you have a DMM? It might be a good idea to check your voltage. It should be around 12v with the engine off and 13.4v-14.4v while running.
    Dec 2010
    Yeah, new coilpack. Mm yeah, what should I clean the area with? And no I don't have a DMM. But I know someone who does.
    Dec 2010
    My battery is from Costco.. LOL.
    Feb 2010
    SL,UT
    Remove the turbo timer, they are worthless on water cooled turbos... clean the ground areas with a wire brush and some electrical cleaner... You can get a multi meter from Harbor Freight tools for less then $10, a good investment for the DIY garage mechanics...
    Hawk-Eye Alliance #801
    Dec 2010
    Thanks for the tips! I'll definitely remove it this weekend and invest in a a multi meter.
