Outside Temp Off?
Results 1 to 3 of 3
This is a discussion on Outside Temp Off? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; So I just got my 08 WRX and have been noticing that the outside temp gauge seems off, them temp ...
    Jul 2011
    Napa, California
    Question Outside Temp Off?
    So I just got my 08 WRX and have been noticing that the outside temp gauge seems off, them temp always seems low.
    How do I fix this? Where is the temp sensor so I can move or change it?
    I know there is an aftermarket intake, could that be affecting the sensor?
    I am new to the WRX world so I have lots of questions
    Mar 2009
    Fairbanks AK
    Mine always seems to be about 4 degrees high. I don't know 0f any way to fix it unfortunately. Just so you know it's not capable of reading below -22 either.
    "You have enemies? Good. That means you've stood up for something, sometime in your life."
    - Winston Churchill
    Aug 2009
    Canada/Ethiopia/Madagascar
    At the end of the day it's not an optimal placement of a temp sensor if you're after accuracy. It's shaded (one requirement for accuracy) but it's not open to the air flow in every direction, and there are a lot of sources of radiant heat nearby. If I park in the sun on a hot day it can read 10C higher than actual temp until I've driven for a few minutes to get the air flowing. When I'm in motion I'm generally confident that it's +/- a degree or two C.
    Your aftermarket intake won't affect the outside temp sensor unless they went out of their way to remove the front bumper and damage the sensor.
    ...Rob.
