Results 1 to 7 of 7
This is a discussion on Trouble with turbo on 05 wrx within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I'm a new owner to an 05 wrx its an auto (bought it for wife) seems like it is really ...
    Jul 2011
    I'm a new owner to an 05 wrx its an auto (bought it for wife) seems like it is really slow and wont build much boost unless you really step on it, don't seem like i'm losing or using any oil and i'm not sure if when a turbo goes bad you always lose oil or not in previous times i have. it also got down to around 45 mph when driving in the mountains in Virginia when it was on the floor. be happy to hear any ideas?????
    Supporting Member yamaha_rider619's Avatar
    Jul 2009
    colorado is home, Kansas is the temporary home
    Are there any modifications to the car? Possibility it might have an incorrect tune for the current mods.
    Josh
    2003 Subaru Wrx Vf39'd
    Bugeye mafia #300
    Sponsored By: WRXPro.com
    Moderator Donkey's Avatar
    Da boonies
    Going to need more specific details.
    http://www.clubwrx.net/forums/genera...-question.html
    Regardless it should not loose power or bog down like you described,with the pedal to the floor. Maybe something is impeding exhaust flow (broken catalytic convertor) or fuel flow.
    2002 FORESTER S
    1998 FORESTER S
    Jul 2011
    ok car is 100% stock has around a 120k on it and i was using 87 but started using 93 wich seemed to help some, but still not sure if its right. and also how do i convert MPa to psi?? at 5000 rpm i'm getting .07-.08 on boost is that about right? i have never seen my boost any above .09
    Da boonies
    You should always use 91 octane or higher. Says right in the owners manual and fuel door. All you have to do is Google "convert MPA to PSI".
    2002 FORESTER S
    1998 FORESTER S
    Jul 2009
    .1mpa is what they stock tune/turbo runs
    Josh
    Bugeye mafia #300
    Administrator TheJ's Avatar
    Dirty South
    +1
    Quote Originally Posted by yamaha_rider619 View Post
    +1
    Click here for more on the stock gauge and MPa
    YOu may want to explore the links in my signature as well.
    -The J
    New Members, CLICK & BOOKMARK these links:
