Stumble after up pipe and silencer mod.
Results 1 to 15 of 20
This is a discussion on Stumble after up pipe and silencer mod. within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I have a stumble that starts at 4000 rpms. Under heavy acceleration. I did the catless up pipe and silencer ...
    Registered User HOTSUBI's Avatar
    Jun 2011
    Rochester, Wa
    I have a stumble that starts at 4000 rpms. Under heavy acceleration. I did the catless up pipe and silencer mod. It has no check engine light or anything else. Car is otherwise stock. I did add a extra ground wire from the batt to the intake..
    04 WRX Wagon. 18's, Catless uppipe, silencer mod..
    67 Cuda 493" big spinny thingy
    63 Savoy 413" 4 speed..
    99 dodge ram CTD modded.
    08 M109R2
    08 Vegas Low
            MainFrame's Avatar
    Austin, TX
    How many miles have you put on the car since the install? It takes about 100 miles for the ECU to adjust and figure out what's going on.
    Jun 2011
    Rochester, Wa
    6 miles. Ok I guess I will drive it some more and check back later with results.. lol Thanks for the input.. also I didnt notice much of a noise difference with the silencer mod??
    08 M109R2
    08 Vegas Low
    Jun 2011
    Rochester, Wa
    So I gotta wait for the fun to kick in!! lol
    08 M109R2
    08 Vegas Low
            MainFrame's Avatar
    Austin, TX
    yeah.. drive it normal for a little while, then get back to us. Unless you have a leak somewhere it should be fine. An exhaust leak should be audible, intake leak might be harder to find.
    Jun 2011
    Rochester, Wa
    Ya it sounds good. No exhaust leaks that I can tell. Purrs like a kitten..
    08 M109R2
    08 Vegas Low
    Jun 2011
    Rochester, Wa
    just not the tiger I was hoping for.. lol
    08 M109R2
    08 Vegas Low
            MainFrame's Avatar
    Austin, TX
    You need a tune, that's where all the power comes from.. and if you're just looking for noise the muffler has more to do with that than anything.
    Jun 2011
    Rochester, Wa
    Ya full turbo back and tuner hopefully soon but not right now. Just want to make sure its reliable. Didnt want that catted uppipe to kill the spinny thing, and the silencer sounded like a good easy free mod.
    08 M109R2
    08 Vegas Low
    Jun 2011
    Rochester, Wa
    Any other thoughts on this issue?
    08 M109R2
    08 Vegas Low
    Supporting Member yamaha_rider619's Avatar
    Jul 2009
    colorado is home, Kansas is the temporary home
    Did you disconnect your battery, drain the power and reconnect it after the install?
    Josh
    2003 Subaru Wrx Vf39'd
    Bugeye mafia #300
    Jun 2011
    Rochester, Wa
    I disconnected it for a hour.. Is there something else?
    08 M109R2
    08 Vegas Low
    Jul 2009
    Are you having any other symptoms?
    Josh
    Bugeye mafia #300
    Jun 2011
    Rochester, Wa
    Nope just the stumble/hesitation. I did find the obd plug. Didnt even see the little pocket for it.. LOL no codes..
    08 M109R2
    08 Vegas Low
    Jun 2011
    Rochester, Wa
    how do you drain the power?
    08 M109R2
    08 Vegas Low
