A/c Help
Results 1 to 5 of 5
This is a discussion on A/c Help within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Bought the car in May, the A/C didnt work. I tried to recharge it once, didnt seem to ever get ...
    Registered User patrick4588's Avatar
    May 2011
    South GA
    A/c Help
    Bought the car in May, the A/C didnt work. I tried to recharge it once, didnt seem to ever get pressure on the gauge. Well a couple days ago, i tried again with a different brand that had a sealant in it (or so the labels says lol). Didnt use a gauge, but it was a small canister, put all of it in. Last 2 days, the A/C has been working kinda. It blows cold ish. Is there anything i can add to make it colder, or perhaps it just needs more r134a?
    If it has ever needed more refrigerant it has a leak.
    Get gauges on it and see what's really going on. I would not mess with the system if I did not have a way of measuring pressures, but that's just me.
    Moderator rage-wrx's Avatar
    Aug 2010
    Yonkers/NYC
    ^^^this.
    T0ny
    2011 WRX
    2012 FXT
    The Big 2011/2012 Mod Thread
    Registered User poly_poly-man's Avatar
    Feb 2010
    Rochester Institvte of Technorcery
    a/c sealant is junk, really.
    If oyu can find stuff with leak detection dye (and ONLY leak detection dye), put that in, and find the leak (the leak also might look wet if it's bad enough). It's probably an o-ring or smth. Bring your system down to 0 pressure (a shop can help you with this), fix the problem, let a shop refill it.
    My big thread: The Used WRX Buying Checklist - Please Contribute!
    My current car: 2002 WRB WRX Wagon.
    Mods: GM BCS, Carberry SD rom, uppipe, AEM UEGO, Klunk Killer, F+R shifter bushings, head unit
    May 2011
    South GA
    it rained today, so temps outside were down. AC blew pretty cold. I have a gauge at my parents house, ill check out whats going on next time i go to WR.
