Oil changes?
Results 1 to 15 of 26
This is a discussion on Oil changes? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Subaru sugests Mobil 1 every 7,500 miles. any sugestions from the rank and file? Thanks, OT...
    May 2011
    Bolton Valley, VT
    Oil changes?
    Thanks,
    OT
    It pays to Play!
    Registered User shadowpr's Avatar
    Jan 2011
    TX, NY
    do what they suggest until warranty is over.
    Moderator rage-wrx's Avatar
    Aug 2010
    Yonkers/NYC
    Quote Originally Posted by outthumped View Post
    Thanks,
    OT
    Really?where did you hear that?SOA has stated that all 2011 turbo models need Subaru Synthetic Oil every 7500 miles.
    T0ny
    2011 WRX
    2012 FXT
    The Big 2011/2012 Mod Thread
    Jan 2011
    TX, NY
    i think he meant synthetic mobile 1. I know my old dealership said that's what they used, so maybe he got that from them.
    Gold Member lokey's Avatar
    Jan 2011
    Crofton, MD
    I use Motul every 3-4K.
    Greg
    Build Thread
    ProTuned Stage 3ish '11 WRX Ltd HB (SWP) ~ 354 awhp 404 ft-lb tq on E85
    Friends don't let friends drive Mitsubishis.
            MainFrame's Avatar
    Austin, TX
    Using Mobil 1 5w-30 is like trying to lubricate your engine with piss..
    ClubWRX.net Vendor adam@kronosperformance's Avatar
    Nov 2005
    Princeton, NJ
    7,500 Miles is a long time without changing fluid and filter. At least make sure you have oil in because its pretty common that people using Mobile 1 notice a decent burn off before 3,000 miles.
    7,500 miles is an almost embarrassingly short period of time but that's what SOA have dictated for warranty, so that's that.
    Keeping the car topped off is of course imperative.
    May 2011
    NJ
    I hope this isn't seen as me hijacking this thread, but the crush washer on the oil plug bolt... which way does it go?
    "when the turbo spools, it's like you're in a time machine"
    Jan 2011
    TX, NY
    lol. What would you suggest?
    Registered User anxiouz's Avatar
    Aug 2010
    So Cal
    The official word is 7,500 miles per interval but interestingly on the "Service Maintenance Contract" thingy where you all oil changes and scheduled maint are covered, the interval is only 3,500 miles per oil change.
    Personally I don't trust going over 5k miles per oil change on any car for any type of oil. But that's just personal opinion.
    Steve // 2010 Cadillac CTS-V // 2011 WRX hatchback (SOLD)
    Jul 2010
    Cincinnati
    3k miles, Castrol Synthetic. You can't change oil too often, and you can't undo the damage done by not changing it enough. That's just my theory on it
    Stink eye mob #727
    2011 WRX DGM Hatch, Protuned Stage 1
    Nov 2005
    Princeton, NJ
    I'm currently running Nippon ENEOS Motor Oil and Gear Lube...so far so good with it. Really smooth shifting.
            MainFrame's Avatar
    Austin, TX
    Quote Originally Posted by shadowpr View Post
    I use Rotella T6 5w-40 now, it's inexpensive, high in zinc, and performs really well on just about every UOA I've seen. I've also heard good things about German Castrol, but it's more difficult to find. If budget isn't a concern then the Amsoil 5w-40 formulated with high zinc content is an excellent choice.
    I used to run Mobil 1 5w-30 and ~1qt would vanish every 3000 miles. Someone did an analysis on it with less than 1000 miles and it had already sheared to less than 20 weight. When you go to change your oil and it pours out of the pan with the consistency of water it's not a good thing.
    I think Mobil 1 5w-40 would be fine to use as well. Generally, the greater differential between cold and hot weights the more resistant the oil is to shearing.
    The end all engine oil resource - - Bob is the Oil Guy
    Mar 2011
    Well since I am a noob I just filled my car with Mobil 1 5w30. Should I change it ASAP?
