Results 1 to 8 of 8
This is a discussion on 2002 WRX turbo problem..Need help!! within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I bought a 2002 wrx with a blown transmission and 150,000 miles because i got it for a great price. ...
    Registered User Otto646's Avatar
    Jul 2011
    I bought a 2002 wrx with a blown transmission and 150,000 miles because i got it for a great price. i recently had everything repaired and put it on the road. i put maybe 2,000 miles on her and i seem to be having a turbo issue. When i first start the car and go through the gears the turbo will spool fine and good power..later on the turbo will start to sputter when trying to spool, and if i try to push on the car a third time the turbo will not spool at all and I loose a massive amount of power. The weird part is if i turn the car off and let it sit, then drive it again, the same process happens all over again. If anyone has had a similar problem or any advise it would be greatly appreciated, thanks.
    Registered User batorr's Avatar
    May 2011
    Rochester, New Hampshire, United States
    any CEL's? it could be the boost solenoid.
    ClubWRX.net Vendor KronosPerformance's Avatar
    Nov 2005
    Bordentown, NJ
    Quote Originally Posted by batorr View Post
    Thats a good point.
    ClubWRX.net's #1 Vendor! - www.kronosperformance.com - Call/Text 732-742-8837 |
    AIM Screenname - KronosParts | GoogleTalk - sales@kronosperformance.com | Military Discount
    [/SIZE]
    USE COUPON CODE FIRST5%OFF to receive a discount of your first order
    Kronos has Special Pricings on Process West & Agency Power!
    CONTACT US DIRECTLY FOR SPECIALS AND PROMOTIONS
    Jul 2011
    Yeah the check engine light came on, but that was two days after I first noticed the problem..you think it could still be the boost solenoid?
    Nov 2005
    Bordentown, NJ
    Quote Originally Posted by Otto646 View Post
    Do you know what that code was for? No flashing check engine light right?
    [/SIZE]
    Jul 2011
    Quote Originally Posted by KronosPerformance View Post
    The light is'nt flashing but i'm not positive what the code was for.
    Nov 2005
    Bordentown, NJ
    Def start with the check engine light first and see what is coming up. Then you can go from there.
    [/SIZE]
    Texas, United States
    It could be any number of things.. is the car up to date on maintenance? I had a similar problem and after rebuilding the engine, replacing crank and cam position sensors, and cleaning all the grounds, it ended up being a bad coilpack.
