How to repair scratches on a front lip?
Results 1 to 11 of 11
This is a discussion on How to repair scratches on a front lip? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Let me preface by saying I'm an asshat... My wife and I went to DC yesterday to enjoy some fireworks ...
    Registered User economatic's Avatar
    May 2009
    Bend, OR
    My wife and I went to DC yesterday to enjoy some fireworks so we parked in her work garage since she has a parking pass on M street in Georgetown. She warned me not to go up one of the side streets but I thought I knew better...bad move. That was even after she told me she witnessed that street injure many a Porsche. Luckily the bumper has some give so I didn't leave any bits behind but scraped up my STI front lip. I was expecting much worse with the noise it made but ended up with this:
    Any ideas how to fix this? Maybe some fine grit sandpaper and do some wet sanding? Seems like it would work well enough to hide the damage with the black plastic.
    Lesson learned: Listen to your wife/girlfriend once in a while. (maybe...)
    May 2007
    orlando flawduh
    Sand it and repaint it
    Or throw a **** ton of wax on it once a week lol
    desiree
    May 2009
    Bend, OR
    It wasn't painted--just the flat black plastic. I'd prefer not to paint it because...well...it will be painted and show scratches and chips more easily. I'm curious if I could get away with sanding and polishing it without looking like ****. Any thoughts?
    May 2007
    orlando flawduh
    Honestly I've painted both of my front lips satin black and my scratches looked just the same as the ones you have.
    Im not sure about sanding and polishing without paint
    I guess maybe try it and see what happens
    Worst case scenario: paint it. Lol
    desiree
    Registered User SPT2011's Avatar
    Apr 2011
    NJ
    use a black sharpie and fill the spots
    hard wax will not work its not painted... you can use spray wax and kinda scrub it to get some blemished out maybee but to be honest just touch it up with something black you probably wont be able to tell
    if you sand it its going to look worse if you dont paint it after sanding
    11WRX Ltd - COBB Stage 2+AEM HWG 93 Octane
    COBB Downpipe - SPT Exhaust - AEM Intake
    Pioneer AVIC-Z120BT - JL Audio W6v2 & XD600/1
    May 2009
    Bend, OR
    Quote Originally Posted by wrxtreme06 View Post
    Painting isn't an option right now since I don't have a garage. But yeah, I like your idea--give it a shot and default to painting if sanding/polishing doesn't work. I'll probably try sanding the underside as a test and if it fails I'll look at the scratches for a few months.
    Quote Originally Posted by SPT2011 View Post
    The problem is matching the color. My luck it would be more noticeable than the scratches.
    Apr 2011
    NJ
    if i was you I would just paint the whole lip and match it to the color of your car.
    Registered User AmateurX's Avatar
    Jul 2009
    Troy, Michigan
    Isn't that plastic black throughout? Can't you just buff it out?
    2011 WRX Limited, DGM; full tint, SPT CBE/STS w/ bushings, RA flaps, Enkei PF01s, Pink SuperTones, and ClubWRX.net stickers!
    My Photostream
    about.me
    May 2009
    Bend, OR
    Quote Originally Posted by AmateurX View Post
    Yep, it is plastic with no paint. That was really my question--how will it turn out if I do some wet sanding with really fine grit and polishing? I've never done anything like at on plastic so I was curious if anyone has and if so, how to do it.
    This is my fallback plan. I have DGM paint in a can that I used for the grill and chrome trunk piece. My only concern is how it will hold up over time. The way the front end of the car is chipped with factory paint I can only assume it will be worse with rattle can paint.
    Aug 2009
    Canada/Ethiopia/Madagascar
    Quote Originally Posted by economatic View Post
    I don't picture this being easy to do right and match the appearance of the rest of the lip. You may not have the scratches any more, but you could end up with a larger area of slightly differing finish. The entire lip may be molded from the same plastic all the way through, but the outside probably has some type of coating or treatment. If you do try this I'd find a small out of the way area to thoroughly test it on first.
    ...Rob.
    Apr 2011
    NJ
    I would leave the lip until you can get it professionally painted it should cost around 80 bucks its so small!
