AC Troubleshooting
Results 1 to 10 of 10
This is a discussion on AC Troubleshooting within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Hi guys, I know there have been a lot of AC related posts and I've read them all. So please ...
    Apr 2009
    West Lafayette, IN
    AC Troubleshooting
    Hi guys, I know there have been a lot of AC related posts and I've read them all. So please bear with me.
    The system was empty from the beginning. I used a vacuum pump and it was able to hold -30psi for 2 hours.
    I tried filling it with refrigerant on the low side but it went to 40 psi (at 29 degrees C) after 3 seconds and it looked like the system would not take anymore refrigerant. I tried the AC and the compressor was running, but still no cold air.
    My guess is that the expansion valve is stuck?
    Supporting Member yamaha_rider619's Avatar
    Jul 2009
    colorado is home, Kansas is the temporary home
    Did you try putting more refrigerant into after you tried the ac?
    I don't per se know your problem, but it should take refrigerant pretty easily.
    Josh
    2003 Subaru Wrx Vf39'd
    Bugeye mafia #300
    Apr 2009
    West Lafayette, IN
    yes, I tried with the AC on and checked with manifold gauges, low side was 70psi and high side was 250psi. Reached this pressure in 5 secs
    Jul 2009
    Are you sure the refrigerant isn't full, it would stop taking if it was full. I cant remember the steps exactly, but I just did it not even 6 months ago and it was basic and simple.
    Do your ac compressor wine?
    Josh
    Bugeye mafia #300
    Apr 2009
    West Lafayette, IN
    The system was empty before starting the recharge.
    The compressor does make a sound, not sure if its a whine
    Jul 2009
    Your compressor is on its way out.
    Josh
    Bugeye mafia #300
    Apr 2009
    West Lafayette, IN
    Problem solved. I forgot to rev the engine to 1,500 rpm
    But I noticed something funny, one vent seems colder than the others...
    Jul 2009
    Give it some time and use before diagnosing that.
    Josh
    Bugeye mafia #300
    Apr 2009
    West Lafayette, IN
    Oh crap I can hear a leak. If you can hear it must be big
    Jul 2009
    Might not be big, Ac leaks turn into gas as soon as it hits the atmosphere. I have heard of the Ac leak fix one car, might not hurt to try that...
    Josh
    Bugeye mafia #300
