doing a maintenance tune up on my car
Results 1 to 15 of 25
This is a discussion on doing a maintenance tune up on my car within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; beside spark plugs and wires what else do i need to check for when doing a 65,xxx miles maintenance Tune ...
    Registered User oldbroadway's Avatar
    Jun 2011
    Hartford,CT United States
    beside spark plugs and wires what else do i need to check for when doing a 65,xxx miles maintenance Tune up my car.
            MainFrame's Avatar
    Austin, TX
    Our cars don't have plug wires..
    Someone should have a 60k rundown somewhere, I'm too lazy to look right now. I know it includes flushing nearly every fluid, and changing the spark plugs.
    Jun 2011
    ooh thats right it has boots. apparently no auto shop has the ones for my car. thank bro. ill need to do some homework on this.
            MainFrame's Avatar
    Austin, TX
    Just google the factory recommended maintenance schedule, it shouldn't be hard to find a run down of what all is included.
    Jun 2011
    Thanks.
    May 2007
    orlando flawduh
    My.subaru.com
    Register and you can view the full maintenance schedule
    desiree
    Mace Windu devilfluff's Avatar
    Feb 2005
    south jersey
    60k on a WRX:
    spark plug replacement
    brake fluid flush/replace
    coolant flush/replace
    rear differential fluid replacement
    transmission fluid replacement(manual or auto)
    fuel filter replacement
    check air filter, replace if necessary
    rotate tires
    Some services may not be due depending on what work you've done on the car recently, of course.
    oil & filter change
    Dirty Jersey
    Part-Time Grammar Nazi
    RIP- '02 PSM Wagon
    SOLD- 08 Candy White MK5 GTI 6spd
    '15 WRB BRZ Limited, 6spd
    Moderator:Tri-State and Transmission & AWD forums
    Jun 2011
    thank you. i appreciate the help.
    Jun 2011
    Maintenance Details 60k+ WRX05
    After doing some Homework this is what i found
    Maintenance Details
    Vehicle: 2005 Impreza WRX SEDAN
    Interval: 60,000 miles / 60 month service
    Inspect
    Drive belt(s) [Except camshaft]
    Inspect
    Camshaft drive belt
    Replace
    Engine oil
    Replace
    Engine oil filter
    Perform
    Replace engine coolant and inspect cooling system, hoses and connections
    Recommended Performance
    Replace fuel filter and inspect fuel system, hoses and connections
    Replace
    Air cleaner element
    Replace
    Spark plugs
    Inspect
    Transmission/Differential (Front & Rear) lubricants (Gear oil)
    Inspect
    Automatic transmission fluid
    Replace
    Brake fluid
    Inspect
    Disc brake pads and discs, front and rear axle boots and axle shaft joint portions
    Inspect
    Brake linings and drums
    Perform
    Inspect brake lines and check operation of parking and service brake system
    Inspect
    Clutch operation
    Inspect
    Steering and suspension
    Recommended Inspection
    Front and rear wheel bearing lubricant
    Perform
    Rotate and Inspect Tires
    Feb 2005
    south jersey
    I'm too lazy to type up the inspections.
    Dirty Jersey
    RIP- '02 PSM Wagon
    Jun 2011
    lol, no worries.
    They recommend inspecting, but replace the transmission / rear diff fluid. It's not that expensive, and worth your time.
    Resident Tuner @ WTF Tuning
    Jun 2011
    Changing spark plugs and flushing liquids is one thing, but changing the transmission now that I don't know how to even begin doing.
    ClubWRX.net Vendor adam@kronosperformance's Avatar
    Nov 2005
    Princeton, NJ
    Quote Originally Posted by oldbroadway View Post
    He was saying change the transmission and rear diff fluid...they're kinda together. He wasn't saying change the transmission lol
    Jun 2011
    Hahaha! I see.
