timing belt inspection
Results 1 to 8 of 8
This is a discussion on timing belt inspection within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; After a hour searching I gave up so.. How can I tell if the timing belt has been changed? Looks ...
    Registered User HOTSUBI's Avatar
    Jun 2011
    Rochester, Wa
    After a hour searching I gave up so.. How can I tell if the timing belt has been changed? Looks like the drivers side cam sproket cover will come off? Did they use a subaru belt? Our car has 118k and I am a tad bit nervous it hasnt been done..
    04 WRX Wagon. 18's, Catless uppipe, silencer mod..
    67 Cuda 493" big spinny thingy
    63 Savoy 413" 4 speed..
    99 dodge ram CTD modded.
    08 M109R2
    08 Vegas Low
    Jun 2011
    Rochester, Wa
    it there any way to tell for sure if its been changed?
    08 M109R2
    08 Vegas Low
    Aug 2008
    Kennett Square, Pennsylvania
    So I assume you have no history on the car at all? You can pull the cover off ( they are all 10mm bolts ) all the replacement belts say SUBARU on them however at 118k miles if it hasnt been changed the word SUBARU will most likely have been worn off. The timing belts on pretty much all Subarus in general are very simple to replace if you have some mechanical aptitude, with the exception of the triple timing chain EZ36 which obviously doesnt require replacement.
    Registered User Jusino's Avatar
    Jan 2009
    Holyoke, MA.
    if the name of the belt is unreadable, then its hard to tell if it has been done.
    but if your going to change the timing belt, and looking for a timing belt. i have one for sale... um, belay my last.. you have a 2.0, the belt if for 2.5. Gate T328 timing belt -p/n: OHC328. not sure its for your though.
    MANNY
    HAWK-EYE ALLIANCE #134
    https://www.facebook.com/L1G3R
    2007 WRB WRX TR, Stage 2.5, SPT Intake, Full Invidia 3" Exhaust w/ N1, ISC Coilovers, 17x8 RPF1 w/ Hankook VENTUS V4, DIY Engine Grounding.
    Jan 2009
    Holyoke, MA.
    this is the actual listing of Gates catalog. as it says, your engine takes a T328 belt also, compared to the EJ25 engine.
    MANNY
    Jun 2011
    Rochester, Wa
    Ok got the cover off and its a subaru belt the lettering is in blue its faded but readable. any ideas?
    08 M109R2
    08 Vegas Low
    Jul 2004
    Seattle, WA
    Does the belt look like it's in good condition? IE no hairline cracks.
    If it's in good shape and the text is readable then it's likely been changed.
    Jun 2011
    Rochester, Wa
    it looks pretty good to me I can read all the part numbers on it no cracks..
    08 M109R2
    08 Vegas Low
