Alarm audiable "beep" dying?
Results 1 to 7 of 7
This is a discussion on Alarm audiable "beep" dying? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; My 05 wrx has a factory alarm that makes the single "beep" when armed and double "beep, beep" when disarmed ...
    Registered User WagonGuy's Avatar
    Sep 2005
    Chicago
    My 05 wrx has a factory alarm that makes the single "beep" when armed and double "beep, beep" when disarmed (I guess most imprezas do that). 2 days ago I noticed the beeping became weak, almost as if it's running out of juice. Is there a separate battery that powers the alarm?
    Blobeye Syndicate #1337
    man vs technology blog
    MvT@YouTube
    No. You can test this yourself by setting off the alarm and disconnecting the battery.
    May 2005
    Phillytown, PA
    Do you mean the lock/unlock chirp? If so, mine is now non-functional/intermittent/faint/perfectly-fine depending on what mood it is in.
    Sep 2005
    Chicago
    Quote Originally Posted by wrx wagone View Post
    Exactly that, the chirp. Mine seems to be moody as well, it was barely audible yesterday but just fine this morning and then very faint after 15 minutes. You don't happen to know the reason and/or solution by any chance?
    MvT@YouTube
    May 2005
    Phillytown, PA
    Quote Originally Posted by WagonGuy View Post
    Unfortunately no, and it's not very high on my to do list at the moment. It is rather comical sometimes, the anemic chirp.
    Registered User poly_poly-man's Avatar
    Feb 2010
    Rochester Institvte of Technorcery
    the horn that is bolted onto your passenger strut tower - replace it.
    My big thread: The Used WRX Buying Checklist - Please Contribute!
    My current car: 2002 WRB WRX Wagon.
    Mods: GM BCS, Carberry SD rom, uppipe, AEM UEGO, Klunk Killer, F+R shifter bushings, head unit
    Registered User jgardiner's Avatar
    Oct 2010
    Calgary, Canada
    I read on somewhere that the "chirper" dies after a while due to corrosion. This might be the problem. IIRC the guy took it apart and soldered a couple of connections to fix it.
