Boost Leak!!
Results 1 to 15 of 17
This is a discussion on Boost Leak!! within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; When at full throttle my car hits its targeted 16psi then slowly drains down to like 8psi or so! Is ...
    Registered User Shansen2's Avatar
    Mar 2010
    Spearfish, SD
    Boost Leak!!
    When at full throttle my car hits its targeted 16psi then slowly drains down to like 8psi or so! Is this due to a boost leak or could it be something else? And if it is a boost leak what are the main vacuum lines and stuff i need to check for holes? Or could it be something else?
    Thanks for the help guys, i'm really at a loss for what to do right now!
    ClubWRX.net Vendor adam@kronosperformance's Avatar
    Nov 2005
    Princeton, NJ
    Its def a boost leak. If you have the factory top mount, check the intercooler hose underneath for any holes and check your inlet tube that connects to your turbocharger for any possible holes or leaks there. Those are the 2 typical spots for boost leaks.
    Moderator Donkey's Avatar
    Da boonies,Va
    It's not a boost leak if thats how the ecu was tuned. You have not given enough info to even determine if it's a problem. On the stock turbo you going to hit max boost quick and taper down,espcially at high altitudes. Also it generally helps to list your mods and if this is all of a sudden happened or the car has always been like this. Details are key.
    ***How to Ask a Technical Question!**
    2002 FORESTER S
    1998 FORESTER S
    Nov 2005
    Princeton, NJ
    It will taper down...2...3 PSI, not 8 PSI (half of what he's making).
    Gold Member lokey's Avatar
    Jan 2011
    Crofton, MD
    BOV?
    Greg
    Build Thread
    ProTuned Stage 3ish '11 WRX Ltd HB (SWP) ~ 354 awhp 404 ft-lb tq on E85
    Friends don't let friends drive Mitsubishis.
    Jan 2011
    Crofton, MD
    With 2 gurus subscribed, I have to ask. Hopefully, this doesn't seem like a hijack, since it is related - I was thinking of replacing my stock BOV with a fully recirculating one. (like this - Forge Recirculation Valve Subaru WRX 2009-2011 / Legacy GT 2005-2009 at RallySportDirect.com) Is there any downside to not venting ANY air to atmosphere?
    Greg
    Build Thread
    Nov 2005
    Princeton, NJ
    Quote Originally Posted by lokey View Post
    Recirculate is the way to go. I don't have that year vehicle but I have the Forge BPV runs great.
    Aug 2009
    Canada/Ethiopia/Madagascar
    Quote Originally Posted by KronosPerformance View Post
    The TD04 will taper down to ~8-9 psi.
    ...Rob.
    Jan 2011
    Crofton, MD
    Thanks, man.
    Greg
    Build Thread
    SuperNova 06wrx4me's Avatar
    Jun 2006
    Nor Cal
    Oh no stock turbo can taper that much.
    Quote Originally Posted by mudferret View Post
    Yup. Mine peaks at 17psi then tapers to 10 psi
    2016 Challenger Scat Pack
    1973 Nova
    2014 Ford Fiesta ST <sold>
    COILOVER TABLE
    TURBO TABLE
    Mar 2010
    Spearfish, SD
    Sorry guys, i have the cobb stage two tune, up pipe with external wastegate, and full exhaust.... Stock turbo and bov
    Nov 2005
    Princeton, NJ
    I had the stock TD04 as well and it do that for me.
    I still say it is a leak. Check everything over.
    Da boonies,Va
    My expirence has been if it was a boost leak target boost would not be hit and usually will be hitting a certain psi and flattening out,not tapering down that low. But hey,could be wrong. So,your running an OTS map with an external wastegate?
    2002 FORESTER S
    1998 FORESTER S
    Mar 2010
    Spearfish, SD
    Yes i am, for now! I was wondering if that could be a part of the problem, but it ran fine for the first few months after i installed the wastegate.
    Jul 2010
    Cincinnati
    Quote Originally Posted by Shansen2 View Post
    It's certainly not ideal. You never stated when this started to happen. Do you know it was running ok or did you assume that it was running ok because it didn't exhibit these symptoms until recently?
    Stink eye mob #727
    2011 WRX DGM Hatch, Protuned Stage 1
