missfire.. plz help
Results 1 to 12 of 12
This is a discussion on missfire.. plz help within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; i hav a missfire on cyl 1,2,4.. can a bad cam sensor or a crank sensor be cousing this?? i ...
    Apr 2011
    missfire.. plz help
    i hav a missfire on cyl 1,2,4.. can a bad cam sensor or a crank sensor be cousing this?? i already went through a list dat was posted here before and nothing
    Moderator Donkey's Avatar
    Da boonies,Va
    If it was a bad cam or crank sensor you would be getting a CEL with a DTC. You could try wiping the faces of the sensor off. So you tried every single thing on that list?
    IF YOU HAVE A MISFIRE CODE ,PLEASE READ THIS!!!
    2002 FORESTER S
    1998 FORESTER S
    zax
    zax is offline
    Super Modulator zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    You might start by also posting your current modifications and year/model of Subaru.
    Zax's Shaggin' Wagon (SOLD)
    Facebook me here
    Apr 2011
    my car is a 2002 subaru impreza wrx wagon.. and its completly stock..yeah i tried everithing on the list but im going to go over it one more time today just to make sure..the car was running fine, i removed the intake to re move the tgv cuz it was stuck.. once i put everything back together started missfiring.... im going to check one last time through the LIST to see if i left out something
    Apr 2011
    OK, right now im testing the coils.. wen i pull out the coils, groung them from their copper circle to the chasis with a wire, put the spark plug on top.. i crank the car and the spark goes to one side of the coil instead to the spark plug.. is this normal?? or the rubber boots r damage?? the boots look perfectly fine though..
    Aug 2008
    Kennett Square, Pennsylvania
    Check the 2 large joint connectors between the battery and washer bottle, if they come unseated even a little bit they can cause misfires, I have seen this happen more than once...
    Apr 2011
    ok.. let me check those connectors.. but are the coils supose to do that though??
    Apr 2011
    ok i found out that coil pack for cyl 4 is completly dead.. i also runned a compression test and the results were cyl 3=150, cyl 1=80, cyl 2=140, cyl 4=80.. wat do u guys think??
    Moderator T0rque's Avatar
    Dec 2004
    Medford, Oregon
    Did you tune for the tgv delete? Did you run a larger injector?
    Lead Wrench @ WTF Tuning, LLC
    Apr 2011
    the tgv is there.. it wasnt remove.. its working now.. the car is stock.. no large injectors
    Dec 2004
    Medford, Oregon
    Did you do the compression test correctly? Was that wet or dry? Did you do both? Did you do a leak down test?
    Apr 2011
    the way i did the compression test is dat i screw the compression gauge were the spark plug goes and disable the ignition and crank the car.... wats a dry test?? is it wen u put oil in the chamber? and wats a leak down test? vi would like to know, prob im doing it wrong
