help assembling fuel lines
Results 1 to 9 of 9
This is a discussion on help assembling fuel lines within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; i hav a 2002 subaru impreza wrx..theres 3 fuel line that come out from the drivers side.. they line up ...
    Apr 2011
    i hav a 2002 subaru impreza wrx..theres 3 fuel line that come out from the drivers side.. they line up from top to bottom. the thinest line being on the very bottom... to wich line those the fuel filter hose goes to??
    Aug 2008
    Kennett Square, Pennsylvania
    the fuel feed line is the one on the very top, the return line is in the middle, and the evap line is the one on the bottom....
    Apr 2011
    is the evap hose the thinest hose?
    Apr 2011
    ok.. i had the feed and return line backwords.. i already put them co0rrectly but the car wont turn on.... and there is lack of fuel pressure.. wat can it be??
    Do you have electricity? Does the pump prime?
    Apr 2011
    yeah the fuel pump is running
    Apr 2011
    how can i check if theres spark??
    Aug 2008
    what exactly did you do to the vehicle in the first place, like what repair where you making?
    Apr 2011
    ok i found out that the crank sensor wire was riped.. the thing is that i dont know wich wire goes to wat side ofr the conector.. it wires riped from the very inside of the conector... wat happens if i crose the wires from the connector? can i damage the sensoer os the PCM??
