02' WRX Some Problems
Results 1 to 6 of 6
This is a discussion on 02' WRX Some Problems within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Okay first when i got my car aligned they said the rack and pinion is a leaking, so i let ...
    May 2011
    Chicago, Illinois, United States
    Okay first when i got my car aligned they said the rack and pinion is a leaking, so i let the car **** a couple hours or longer nothing on the ground just as safety i put some lucas ps fluid plus stop leak, and i monitor the fluid level nothing has changed same for the last 3 days or more.
    Second when i shift into first and start to go and let the clutch out when im out pretty much it makes a noise that sounds like to little metal bars hitting each other i had a friend drive and looked under the car and nothing hitting the ground so thats another problem.
    Third when in first or second at low rpms it jerks a little.
    You are not actually asking anything but here goes:
    1. Find the leak and fix it.
    2. Sounds like a clutch throw out bearing but if you are extremely lucky plus inaccurate at describing the problem it could be a heat shield. Unlikely though unfortunately.
    3. Unknown. Give it more gas.
    - Al Stewart
    For 2. does it make the noise only when pulling off? Does it make the noise when the car is standing still with your foot OFF the clutch?
    - Al Stewart
  5. #4
    May 2011
    for number 2 its only when im pulling off
  6. #5
    OK then I'm a bit stumped. I had a car do that when the clutch was worn, sounded like a screech when pulling off in 1st. Other than that I don't know.
    - Al Stewart
  7. #6
    May 2011
    Not a screech like two sticks hitting each other I'll video it it's been working fine so I might have my super hearing activated haha
