Engine and turbo questions
Results 1 to 6 of 6
This is a discussion on Engine and turbo questions within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Hey everyone, I'm a new proud owner of a 2002 subbie and I just had a couple of questions concerning ...
    May 2011
    Hey everyone,
    I'm a new proud owner of a 2002 subbie and I just had a couple of questions concerning the engine and turbo. First, I've noticed that my boost gauge only hits about .07 mPa. Is that the max for a stock turbo? I've only filled the car up once and that was with the 89 fuel, I now know that I should use premium only. Will that make much of a difference? I am also concerned about how fast the engine heats up. I'll only be driving it for about a mile or so and by the time I shut it off, the heat coming off the engine is incredible. My oil and coolant levels are fine, is it just the turbo that heats up quickly?
    Thanks,
    Nicolas
    Dec 2003
    Dallas, TX / Sterling, VA
    There is a label that says "Premium only" on you gas cap. Your manual says "required" not "recommended". Therefore, you only use premium, period. What difference? How much does an engine cost? How much is a few less mpg worth to you?
    Don't worry about engine heat.
    Registered User batorr's Avatar
    May 2011
    Rochester, New Hampshire, United States
    you car's computer is programed to run off of the octane levels found in premium gas so running with a lower grade will effect the car's preformance level. as for the heating part they do tend to warm up faster then non turbo cars.
  5. #4
    Registered User Spiffy's Avatar
    Feb 2011
    Utah
    My stock 2007 wrx warms up to normal operating temps within 5 minutes of driving. I have never owned a vehicle that warms as quickly as this one. As long as its not overheating you are fine. I've got an oil temp gauge (drain plug) and have noticed that the oil (synthetic mobil 1) takes a bit longer to warm up,. Once it does though it ranges between 140°F - 180°F depending on how its being driven in the summer (haven't had the car long enough to know what temps will read out in the winter).
    The octane rating of gasoline tells you how much the fuel can be compressed before it spontaneously ignites. When gas ignites by compression rather than because of the spark from the spark plug, it causes knocking in the engine. Knocking can damage an engine, so it is not something you want to have happening. Lower-octane gas (like "regular" 87-octane gasoline) can handle the least amount of compression before igniting. This is why nearly all forced induction engines require high octane fuel.
    the stock 2.0L engine has a compression ratio of 8.0:1 with no boost. At stock boost, 13.5psi the compression ratio nearly doubles. .7bar is equivalent to 10 psi. My advice: Don't use the turbo at all and you should be fine.. or buy some octane boost and balance it out,. still though, take it easy until you get a new tank of gas.
  6. #5
    Jun 2011
    PA
    I have a random question. I picked up a 2008 WRX a little over a week ago. It normally idles around 500 RPMs roughly. But sometimes when I start it up it will idle at around 1500 RPMs. Once the engine is warmed up it'll drop back down. But is it normal for it to idle a little higher when first started.
  7. #6
    ClubWRX.net Vendor adam@kronosperformance's Avatar
    Nov 2005
    Princeton, NJ
    Yes, every car idles high during cold starts.
