Results 1 to 12 of 12
This is a discussion on Topping off "Super Coolant" within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I just bought my 2011 WRX last week and noticed my coolant level is a little low (just under the ...
    dmk
    dmk is offline
    Registered User dmk's Avatar
    May 2011
    Western NC
    Question Topping off "Super Coolant"
    I just bought my 2011 WRX last week and noticed my coolant level is a little low (just under the low mark on the reservoir). I figured I'd top it off to the full mark and check it periodically to see if it stays there. Maybe it had an air bubble in the system and settled during transport or driving.
    My question is, can I just top it off with distilled water, or do I need to buy a jug of Subaru's "Super Coolant"?
    Registered User 2011RX's Avatar
    Dec 2010
    Seattle
    Is it low with the car off? Check the level when it warmed up and running first
    2011 WRX DGM Sedan
    dmk
    dmk is offline
    May 2011
    Western NC
    The manual says check level "while the engine is cool". Then again, I just now noticed it also says "Check the coolant level at each fuel stop".
    I check it again after my commute home from work....
    But the question still remains, is the Subaru coolant compatible with distilled water? The manual seems to recommend straight coolant.
    The blue coolant is prediluted, hopefully in distilled water. I have used either distilled water or blue coolant premixed for such small volumes. The % will not be affected much at all as you are unlikely to add more than, say, 300 ml.
    Registered User jgardiner's Avatar
    Oct 2010
    Calgary, Canada
    If you are in a warmer climate, then distilled water is fine. If you are furthur north then 50/50 is the better option.
    Negative pantsy rage-wrx's Avatar
    Aug 2010
    Yonkers/NYC
    The manual recommends using Subaru Blue pre-diluted coolant.I would stick to the manual.And since the car is just a week old why don't you contact your dealer & tell him of your concern.Its obviously not your fault.
    -Tony
    2011 WRX WRB Stage2
    2012 FXT DGM
    The Big 2011/2012 Mod Thread
    "Just Leave me alone. I know what I'm doing"-
    Kimi Räikkönen
    dmk
    dmk is offline
    May 2011
    Western NC
    Thanks, that's the answer I was hoping for.
    Quote Originally Posted by rage-wrx View Post
    I would do that, but they'll just say bring it in and the closest Subaru dealer is a two hour drive.
    This appears to be a very minor issue. If it loses more, I'll call the dealer, but for now I'm just not familiar with the new high tech coolants and wasn't sure if the Subaru stuff was glycol based and water compatible or not.
    Aug 2010
    Yonkers/NYC
    Fred Bean sells the coolant you are looking for Subaru Super Blue Coolant
    -Tony
    2011 WRX WRB Stage2
    2012 FXT DGM
    Kimi Räikkönen
    dmk
    dmk is offline
    May 2011
    Western NC
    Thanks for the link rage.
    It's odd that they say "Subaru Coolant does not come pre-mixed, it needs to be diluted 50/50 with water", but the jug in the picture says it's pre-mixed "do not add water".
    The older green coolant was not premixed. The newer blue coolant is. Your car almost certainly uses blue.
    Nov 2011
    Oregon
    Dragging up an ancient thread, but I noticed that my wife's brand new 2013 Outback has a factory coolant fill level of just below 1/2 between full and low. My 1 year old 2011 wrx with 10k has a coolant level at an identical level.
    The Fruit mangostick's Avatar
    Oct 2009
    the ghettooooo
    My 2010 did too.. I'm assuming its for expansion purposes. Remember in the reservoir is actually a surplus of coolant. The system has what it needs internally to work properly if you can see coolant in the reservoir at all. That said, I bought a gallon of blue stuff and topped mine up a little. I figure It cant hurt to have some coolant on hand just in case. I usually keep a stock of needed fluids.
    OBP 2010 5dr *traded*
    SWP 2013 FRS
    SUCH IS MANGO!
