ECU Question
Results 1 to 3 of 3
This is a discussion on ECU Question within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; when replacing the ECU with a used one, do I need to "reflash" it or is it just remove or ...
    Registered User Venomswrx's Avatar
    Jan 2010
    ECU Question
    when replacing the ECU with a used one, do I need to "reflash" it or is it just remove or replace?
    Run the same map you had previously. If that means reflashing, then yes; if not, then no.
    Jan 2010
    ok thanks for the help!!
