Results 1 to 12 of 12
This is a discussion on Engine Idling High within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Has anyone had a problem of their engine gradually idling higher when sitting in stop and go traffic? More specifically ...
    May 2011
    Washington, DC
    Engine Idling High
    Has anyone had a problem of their engine gradually idling higher when sitting in stop and go traffic? More specifically in hotter weather? I have an 04 WRX and occassionally the engine will gradually start idling up. Sometimes up to 1,500RPM. Once traffic eases and I get moving, it returns back to 500RPM.
    Registered User batorr's Avatar
    May 2011
    Rochester, New Hampshire, United States
    Is your check engine light on? It could be a few things but a CEL would help narrow it down. Mass air flow sensors, dirty air filter, O2 sensors are a few things that can cause it to idle like that.
    May 2011
    Washington, DC
    no check engine light, o2 sensor was replaced about 4 months ago. I think my only option is to take it to the dealer so they can hook it up to the computer.
    Registered User MakeItRoar's Avatar
    Aug 2010
    Chicago, Illinois
    If your air conditioning is on high, or even on at all, it can increase your idle.
    2006 WRX Limited -Pro-tuned VF-39, STI TMIC, STI factory I/C Sprayer, Throttle body Coolant Bypass, STI Exhaust, SPT Short Ram Intake, SPT Upper Front and Rear Strut Bar, Red Samco Radiator Hoses, STI Trunk, SPT Short Shifter, Aftermarket Rotors, Lamco Turbo Gauge, Catless Downpipe, Hella Supertones, RallyArmor Limited Edition Pink UR Flaps, 35% Tint, Grounding Mod, Walbro 255 Fuel Pump, SPT Heat Shield STI Piston Shift Knob!
    Hawk-Eye Alliance #430
    May 2011
    Washington, DC
    no ac either. I'm pretty up to speed on the general workings of my car. So I filtered out the obvious. Just wondering if anyone else had this issue.
    Aug 2010
    Chicago, Illinois
    Haha, wasn't trying to insult your intelligence by any means. Sometimes people need to be reminded of the obvious.
    May 2011
    Washington, DC
    not a problem. just wanted to clarify for anyone else reading the thread.
    May 2010
    Chicago, IL
    Any luck on figuring this issue out? I'm having the same issue, I thought it was the car overheating but the temp gauge doesn't go up. What does heat soak do? It's the only other thing I can think of.
    Aug 2009
    Canada/Ethiopia/Madagascar
    OP sounds like your cruise control cable tightening in the heat; not uncommon.
    ...Rob.
    [my photos]
    May 2011
    Washington, DC
    Nothing yet. I have an appt tomorrow at the dealership and they're going to hook it up to the computer to see what the deal. Will update as soon as they figure it out.
    May 2010
    Chicago, IL
    You know what, mudferret? I googled this problem, and that was the only thing I could seem to find. Is there a fix to this, or just something common and I have to live with it?
    The fix is to adjust the cable if increased cable tension due to temps is the issue. There was I believe a TSB for this too.
