Sounds like a ground issue to me. With weather warming up, the connections are more likely to loosen up, as well as the metal that keeps these connections in place. Unfortunately, you're going to have a lot of wire tracing to do to find this bad connection. Check your main battery ground to make sure it's secured to the chassis, then move on to other grounds both in engine bay and in the cabin. Good luck dude.
LinkBack URL
About LinkBacks
