Both headlights out. Bulbs are fine.
Results 1 to 9 of 9
This is a discussion on Both headlights out. Bulbs are fine. within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; My headlights worked last night but tonight when i turned them on tonight they didnt come on. Brights work, turn ...
    Registered User KentuckyWRX's Avatar
    Mar 2010
    Florence, Ky
    My headlights worked last night but tonight when i turned them on tonight they didnt come on. Brights work, turn signals work, flood lights work. Checked the 15amp fuses and they were fine. Any ideas?
    Jan 2005
    Eh, whaaaaa?
    What kind of bulbs are in there? Could have burnt up wiring, check the relay for it as well.
    Cody
    Mar 2010
    Florence, Ky
    where is the relay at on an 06wrx?
    How are the bulbs "fine?" Did you test the low beam bulbs? I've had what you describe happen with a short in one bulb. I'd pull the bulbs and test them or at least leave them in place, remove the harness, and test the bulbs across the terminals with a multimeter. If I am wrong, you've wasted 5 minutes only (sorry...).
    Jan 2005
    Eh, whaaaaa?
    If I remember right, the relays for the head lights are in the engine bay fuse box, the two nearest to the firewall at the top of the box, should be right next to each other. One is for left hand, the other for right hand.
    Cody
    Registered User jgardiner's Avatar
    Oct 2010
    Calgary, Canada
    Well, if there is a seperate relay for each light and both of them are out then that's probably not the problem.
    Moderator Donkey's Avatar
    Da boonies,Va
    Multimeter................
    2002 FORESTER S
    1998 FORESTER S
    Jan 2005
    Eh, whaaaaa?
    Quote Originally Posted by jgardiner View Post
    Not necessarily, but in a way correct. If both of them are out, it will mean there is an underlying problem that needs to be searched out, but checking the relays is a good place to start, and doesn't take much time regardless.
    Cody
    Registered User DorBink's Avatar
    Sep 2009
    Houston, Katy
    Isn't it possible to burn out your low beam? I remember having a similar problem with my Mazda. I just drove hOme with my fog and high beams on.
