brakes rubbing
Results 1 to 8 of 8
This is a discussion on brakes rubbing within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I just installed new pads (stoptech) ss lines and ate super blue. I started to drive and heard something rubbing. ...
    Registered User shadowpr's Avatar
    Jan 2011
    TX, NY
    brakes rubbing
    I started to drive and heard something rubbing. Took the wheels off, and used grease since I didn't the first time.
    I still have the rubbing sound. I'm sure its the pads rubbing on the rotor.
    Did I do something wrong, or is this normal? Any help is appreciated.
    Did you properly bed the pads?
    Resident Tuner @ WTF Tuning
    Jan 2011
    TX, NY
    Not yet. Was worried about the rubbing first.
    Aug 2008
    Kennett Square, Pennsylvania
    some rubbing is normal, If you are sure you greased the slides and put a dab on the back of the pads than you should be good to go, Warped rotors can cause a rubbing noise as well as a plethora of other things, but if the noise wasn't there before you installed the pads and now there is a noise present chances are it has to do with the pads...to answer your question though without grease on the slides you will get a rubbing noise...
    Jan 2011
    TX, NY
    I put grease on the back of the pads, and on the clips that are on the calipers.
    Should I have put some anywhere else, and how much?
    Will probably bed them on friday after I get my alignment.
    Quote Originally Posted by shadowpr
    You have a set of camber bolts and a shop that'll align to your specs? If not, then you've got some more shopping to do
    Jan 2011
    TX, NY
    have the camber bolts and an alignment place all ready to go.
    Jan 2011
    TX, NY
    Well I got it all fixed. I took the front brakes off again, and greased it some more. I also found that one of the pistons on the front caliper wasn't getting pushed out. I finally got it to move, and greased that too.
    After I was done, the car would now roll freely if the brakes aren't aplied.
    I now have a squeak in my suspension.... it never ends. lol
