2004 WRX help PLEASE
Results 1 to 6 of 6
This is a discussion on 2004 WRX help PLEASE within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I have a 2004 WRX the mods are UEL header, catless up and down pipe, cobb turbo back exhaust, cobb ...
    Apr 2011
    Oskaloosa, Iowa
    I have a 2004 WRX the mods are UEL header, catless up and down pipe, cobb turbo back exhaust, cobb stage two tune, aem intake, aftermarket intercooler y pipe, exedy stage 1 clutch, and a turbosmart B.O.V. I just recently put in the clutch. I got it all done and took it for a drive, when the motor boggs down if you let it, or you hit a bump, there is a bad rattle coming from the front right. Even when the clutch is pushed in or the car is in neutral or even off it you hit a bump it rattles and chatters bad? When i installed clutch i also put on a strut bar but i am 99.9 percent sure it is not strut rattle. If your on a smooth road and shift smooth to were there is no jerk there in no noise at all, just when the car shakes or jerks does it make the noise. Any ideas?? PLEASE HELP
    Supporting Member yamaha_rider619's Avatar
    Jul 2009
    colorado is home, Kansas is the temporary home
    First of all the intake you have is a piece of junk and not designed for the tune you have. Second, you have no need for the bov, so take it off and replace it with the stock recirc valve.
    Now about your rattle. Best bet is to go through everything to took off, losened and reinstalled. You can have a loose bolt, missing bolt, etc.
    Josh
    2003 Subaru Wrx Vf39'd
    Bugeye mafia #300
    May 2007
    orlando flawduh
    the BOV & UEL header should not be used with an OTS stage 2 map.
    cobbs map notes state specifically what can & cannot be used.
    desiree
    Apr 2011
    Oskaloosa, Iowa
    my car ran great no prob lol i am just needing help about the rattle please
    Aug 2008
    Kennett Square, Pennsylvania
    check your sway bar links and heat shields, I've seen dozens of techs remove transmissions in these cars different ways, some disconnect the links to pop the axles out and others pry on them, if you undid your sway bar links I would check that, if your 100% sure its not a strut/ strut mount. How many miles are on the car? Did you do a stock replacement clutch or did you upgrade at all? depending on the design of the clutch some chatter could be normal... does this happen with the car still? clutch in/out?
    Apr 2011
    Oskaloosa, Iowa
    yeah it rattles when clutch is in or out and i didnt take the sway bar off?
